Lamona washing machine symbols wool cycle - Washing Machines
  • 883 Answers
SOURCE: washing machine wont fill
hmmm...wool requires cold water...I'm guessing that first the hot water and now the cold water solenoid valves have become clogged with sediment. test by turning off water. then loosen the hose connection to each inlet in back of washer. then slowly open water valves and let water pour into wash tub if hose will reach, otherwise pour into a bucket. if water comes out of hose, then look for metal screens at hose connections to washer and clean those. if still no water through solenoids (after re-connecting water hoses) then may need to disassemble solenoids and clean those too.
Posted on Oct 19, 2007
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
SOURCE: my washer is stuck on the wool cycle and won't wash,change cycles
I had the exact problem. I am not sure if this is the fix, but I unplugged the machine over a few hours, then plugged it back in. It stayed off for 20 seconds and then went back to the wool cycle. In frustration, I opened the lid while running my fingers over the cycle select buttons quickly back and forth two times, as I closed the lid, the display cleared and the machine returned to normal, so far anyway. It seemed as if some moisture had gotten in the controls somehow. It was a very humid day and I think that was the problem,after all. My machine is over ten years old, and the only other problem was a clogged drain pump. I used advice from this website to fix that, and saved 300 on repairs at least
Posted on Jul 30, 2009
  • 6277 Answers
SOURCE: Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 27, 2011
SOURCE: My Lamona integrated washing machine
Hi Guys,
My Lamona washing machine is also stuck on rapid wash? Dis you get it resolved?
Kind Regards
Posted on Sep 02, 2011
Why is it beeping and stuck on the wool cycle
will be some blocked up filter or water supply
if its beeping then this is usualy something blocked up with oose
Sep 04, 2014 | Dyson CRO1 Front Load Washer
What cycle is quick wash
What is your model number
Apr 15, 2014 | Washing Machines
Calypso washer display is freaking out.. It
change the panel. buttons are shorted wool button
Feb 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
No manual Lavamat 625 Senstronic
Still looking Lizziehmp?
1 - wash with pre-wash
2 - Quickwash
3 - soft rinse
4 - long spin (4 + woolmark -- short spin for wool)
5 - extre pre-wash / soak program
6 - pump-out
it is actually more complicated as each number above is further modified by pressing combinations of buttons. (see for example 4 above)
E - economy
1/2 - for small loads
funny V symbol - variomatic spin
Leave some contact, I could get you a copy of instruction card
Happy washing.
Voitek
(Warszawa, Poland)
Jan 11, 2009 | AEG Lavamat W1450 Front Load Washer
Gentle cycle
wool cycle but remember this cycle does not end with spin
Sep 06, 2008 | Tecnik TKL9260 Front Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
