My Kenmore Washing Machine wont drain or spin. Only a slight hum.
The machine is only 2 yrs old. It will allow water to come in, but it only makes a very slight humming noise when the lid is shut. I tried playing with the lid to make sure it was not the lid switch, but that didnt work. What could be the problem?
  • 3 Answers
It is most likely the pressure switch assembly ... but wait dont run out to buy parts yet... try this first...
-Remove the front panel off the washing machine.
-Look on the side of the tub for where the pressure hose attaches to the base of it.
-Check for a build up of gunk in the hose near where the tube meets the tub... you'll probably notice wht looks like mildew... usually you can just pull it apart.
-I used pipe cleaners to clean out the end of the tube (you can usually unattach from both ends to make it wasier to work on)
-Now before you put it back together grab a can of compressed air and use it to blow down into where the hose connects (as there is usually a build up there too).
-Reassemble... TADA... if that fixed it you just saved yourself some $$$.
~~~~ Mittonman
Posted on Jan 26, 2009
I have a kenmore elite oasis top loader washing machine. We accidently dropped and entire bottle of detergent into the machine while washing. Now the machine will not cycle, drain or spin, it just makes...
If you can get the unit to run by unplugging it and plugging it back in again.....add liquid fabric softner to the water as it will break down the suds....and prevent suds lock in the pump and ease excessive drag on the basket during spin.
Nov 18, 2010 | Kenmore Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite catalyst wont drain or spin
Did you ever find out what is wrong? This is exactly what has been going on with ours.
Mar 25, 2009 | Kenmore Washing Machines
My Kenmore Washing Machine wont spin or drain. It will allow water to come in, but when the door is shut, it just gives off a slight humming noise. This washing machine is only 2 yrs old, so I'm assuming...
If that didn't work there is another possible solution... I had the same problem... and since I am cheap I like to make sure I try everything I can before buying parts... so heres what you do...
~~~~ Mittonman
Jan 26, 2009 | Washing Machines
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Samsung washing machine WA71N2
can you hear the pump making any noises,if you can (humming sound)then it may be blocked with lint,coins etc.if the pump isnt making any noises then it may be faulty or a broken wire to the pump or you have a no drain button pressed in . hope this helps
Mar 07, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
