Question about GE Microwave Ovens
Jvm1870sf02 no heat and loud noise
Making loud noise when turning on to heat.
If there's a loud noise when you try to microwave food, then the current through the high voltage transformer is probably too high.
Most likely, this is being caused by failure of a component in the high voltage circuit. The most likely component is the high voltage rectifier, followed by the magnetron or high voltage capacitor. High voltage transformers occasionally do burn up as well.
May 27, 2016 | Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave oven started making a loud sound and quit heating
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
Microwave makes a loud noise while using.
Could you describe the noise?
It may be a noisy fan motor or a failing magnetron or high-voltage transformer.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 13, 2007 | Microwave Ovens
Kenmore 62622 (model) -microwave-loud noise -no heating
dis-assemble waveguide and clean thoroughly. try again. if no-go then failed magnetron. get new unit.
Jun 08, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
