Question about Simplicity Performer S110 Mechanical Sewing Machine
Tension problems I'm an experienced sewer but this is a new machine, and it seems that no matter what material, thread, needle I use the tension # needs to be set at 8-9. It's just frustrating to me because the book says that most projects are sewn between 3-5 and I remember it was set at that (about 4) when I first started using it. It is a Singer. I have tried adjusting the bobbin etc. It sews fine at 8 , it just bothers me, and was wondering if there is something else I should check.
  • 84 Answers
Hi bobbin....Because this machine is still unfamiliar to you, be certain that your upper thread is indeed completely threaded into and between the upper tension discs. Typically, raising the Presser Foot disengages applied tension upon the tension discs. It's quite possible that the lever which disengages your upper tension discs has slipped, and is no longer allowing the thread to freely position itself properly between discs. You may also firmly grasp the thread just before the discs, and firmly pulling with your other hand, thereby ensuring that the thread is completely within the discs. If those initial steps have not remedied your situation, examine your bobbin case, and ensure that the flat metal spring has not "cracked", paying particular attention the end where the thread exits the bobbin case under the spring. If the spring appears whole to you, using a screwdriver, in a counter-clockwise direction, turn the set-screw which fastens the spring to your bobbin case 1/5 rotation, and rethread. Set your upper tension to 4, and test sew using a straight stitch with medium stitch length. The knot after each stitch should appear to be in the center of your fabric. If the knot is still well below the center, loosen the bobbin case spring set screw by another 1/5 turn and repeat your test. If you must, you can repeat the process ONE more time, but no more. Remember, the set screw that secures the spring is very short, with little room for error. ****I recommend that you place a towel directly under the bobbin case prior to turning the screw, which will catch the screw and or spring for easy retrieval should you unintentionally dislodge them.....good luck my friend
Posted on Aug 02, 2007
I am having trouble with my Singer sewing machine 367. I can't seem to get the tension right.
You really need to get a manual. Trying to figure out the problems is difficult if you are not an experienced sewer. There is a manual on eBay right now for your machine.
A little about tension. 95% of the time it is the top thread tension. It will be the thread on the bottom of the fabric affected. If the the thread on the top is loose it is the bobbin tension. Do not adjust both at the same time. Start with the top tension making small adjustments and then doing a test on scrap fabric.
Check to see if it is threaded correctly, without a manual it may not be obvious if it is or isn't. Check that the thread is between the tension discs correctly.
Jul 11, 2017 | Singer Sewing Machines
I have a janome DC4030 the top thread keeps breaking on thicker materials,
Make sure the correct length of needle is used and installed correctly. Sometimes it moves slightly out of the holder without falling out but just enough to affect the needle eye position which can cause this kind of problem. For thicker materials use either ball point or denim needles. As last resort the top thread tension might be too tight. Adjust the top thread tension.
Jun 09, 2017 | Janome Sewing Machines
Adjust bobbin tension
Main reasons tension is fouled up: machine is threaded incorrectly, or thread or lint is collected in bobbin compartment. Also, if needle is dull and causing snagging that messes with fabric moving smoothly through pressure feed, you have tension issues. Try those fixes first. Good luck. Needle sharpness is an issue for many new sewers...needle doesn't feel dull, but if you do big projects or really tough fabric, try changing needle every other project or so....and if you are sewing very delicate fabric, you want a brand new needle so it doesn't get snagged......
Feb 10, 2015 | Sewing Machines
Top thread janome tension
it's possible that the spring got damaged & it needs to be check at a sewing machine shop
Mar 19, 2012 | Janome Sewing Machines
I love my machine except when trying to free motion quilt. No matter how loose I set the tension it still pulls the bobbin thread to the top. I also have trouble with the thread breaking and stitches...
Properly balanced tensions are critical. The lower bobbin tension must be tight enough to pull the knots down. To which number is your upper tension set? It should be around three. Skipping stitches is an indicator of hook timing and hook/needle clearance issues.
Sep 01, 2011 | Juki TL-98Q
The upper thread in the backside of the cloth comes bundle and after few stiches the wheel stops with the thread jam in the hook of bobbin. i kept thread tension at 3, 4 and 5 ,cleaned the bobbin and...
Wow, what a challenge. There are a lot of reviews/complaints about how temperamental this model is- sewers either love it or hate it and have the same problems you describe. Since I am an experienced sewer and have lots of vintage black Singer models, ( I got rid of the newer models), I wouldn't mess with it any further...If you can, take it to a Singer authorized repair person....they can sort it out for you. Sounds like you've done everything you could so far. Good Luck.
Jul 23, 2011 | Singer 8280 Mechanical Sewing Machine
Time janome 3018?
when you say 'bobbin thread bunches' i take it that when you look at the underside of what you have sewn it looks messy. if this is the case and the machine is threaded correctly and the the needle thread is tight enough to bend the needle a little when pulled (with presser foot down) it will most likely be that you need to increase needle tension (maybe to max) when sewing thick fabrics with thicker than normal thread.
if the the needle does not bend a little you may not have the thread in between the tension discs, or there may be thread or lint caught in the tension discs preventing proper tension (try pulling a thin rag through the tension discs to dis-lodge any foreign matter).
Jul 17, 2009 | Brother PE-150V Computerized Sewing...
Bernina 66 troulbe with tension
the Berlina uses a reverse hook; from say, singer; over time your hook has slipped and is barely looping the thread: adjust your hook to enter the thread loop about 1/4" before the needle raises to make the stich then readjust the tension on both the bobbin and, the needle
Apr 03, 2009 | Singer 3343 Mechanical Sewing Machine
Simplicity Performer S110 Mechanical Sewing Machine Logo
159 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
