Question about Cannondale Cycling
Cannondale h300 tire size - Cannondale Cycling
What size thread are the pedals on a cannondale quick bike
They are a standard thread - 9/16 x 20. ANY standard bicycle pedal will fit.
May 22, 2017 | Cannondale Cycling
Brake pads for cannondale f4 2008
You're looking for the Shimano B01S pads. The brakes are BR-485's with 160mm rotors.
Jan 05, 2014 | Cannondale F4 CO2
How can I lower my Cannondale E 440 sothat my feet will touch the ground when I am sitting on it and it is not moving?
Hi, Cecil here are some options for lowering your bike depending on your needs and wallet:
1. Rear shock lowering kit.
2. Front fork lowering kit.
3. Shorter rear shocks.
4. Shorter front forks.
5. Thinner padded seat.
6. Lower profile tires.
Please be aware that some of these options or a combination of options will require a shorter kickstand or your stock one modified. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
New Cannondales for 2002 Off Road com
http://www.scottsonline.com/litrack/406.pdf
http://www.cannondaler.com/manuals.php
Cannondale Parts
http://www.blackwidow-ok.com/om
Mar 15, 2013 | 2003 Cannondale E 440 A
Stripped threads in accessory holder for cannondale ultra.. How do I remove old ones and install new.. Drink holder won't tighten down due to bad threads.. Any ideas
I am assuming you are talking about the bolts in the frame for the water bottle holders. You can take it to the bike shop and have them install a "Rivnut." This entails drilling out the frame boss that is stripped, and installing a Rivnut with is a rivet that is threaded for a specific size, in this case, the same size for cage bolts. Or you could order the kit and tools yourself, but then you would be left with extra Rivnuts and tools.
Dec 09, 2012 | Cannondale Bad Boy Ultra
I have a cannondale Q6 2010 and I had removed the saleman remove the front tire so it would be easier to haul in my car. He undid the breaks but when i got home I got the tire back on the frame but need...
after placing the tire in place simply take the brake glide elbow l and after squeezing the brakes together place it in the hanger its the floppy bar on the left side brake arm after fitting these together place the rubber boot on the remainder of the glide and voila your done :) this is based on a v-brake system that was simply opened and had not had cable removed if its another brake style simply leave a comment here stating so and ill walk you through another style if needed ok :)
Feb 26, 2011 | Cannondale Cycling
Will the cannondale xc3 mtb stem fit on my lefty headshock? And how do I do it?
the XC3 stem comes in a 1.5 in clamp designed to fit on cannondale headshox systems. The lefty fork you have may or may not be compatible, you would have to check your fork to see if it is the right size.
There is an XC3 SL conversion kit for lefty forks that are not the same size and includes the stem and steerer replacement.
Swapping stems is quite easy on the cannondale. Loosen the two bolts holding the stem to the steerer and undo the bolts holding the handlebars, remove stem and replace.
If none of this makes sense then I would strongly urge you too take the bike into your local bike shop, preferrably a cannondale dealer, and have them show you. It will take only a couple minutes and they can confirm compatibility.
Jan 06, 2011 | Cycling
Mountain bike advise
sounds like a pretty good bike for what you will be using it for
Oct 22, 2009 | Cycling
Tires
Under well-lit conditions look for any signs of punctures (such as nails or shards of glass) which might potentially lead to a loss of pressure or a blowout. Bulging or cracking might also occur on old tires; make sure you roll your bike forward in order to see all surface areas that come in contact with the road.,
Nov 10, 2008 | 2003 Cannondale E 440
Cycling Logo
89 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
John Egan
John Egan
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
