Question about Dell Inspiron 2650 Notebook
I can't seem to download anything
And I don,t have any feeds
  • crewspc
    crewspc May 11, 2010
    feeds ? RSS ?
Feed dogs lowered can't raise material not feeding thru
Is your machine mechanical? If so, sounds like the feed dogs are stuck in the lowered position. Needs good cleaning and oiling.
Perhaps this will help:
The feed dog knob won turn don think anything is broken haven used the...
Dec 30, 2015 | Sewing Machines
How do I raise the feed dos
Consult your owner's manual. There is a switch, lever, or knob somewhere on your machine that raises the feed dogs. If they are stuck in the down position and your machine is mechanical, could very well be it has seized due to lack of cleaning and oiling.
This may be helpful:
Dropping feed dogs
Manual seems to imply that you have to cover the needle plate with a "darning plate," which just build up the area around the feed dogs so they don't reach the fabric--pretty inelegant, plus I wonder if you can even find the darning plate anymore. Let me know if you figure out anything else!
Jul 17, 2012 | White Sewing 1418 Mechanical Sewing...
Hi do I need a video card to read/play dvds on my 760GXK8MC m/b based computer. I've tried downloading codecs but they don't seem to help?
Hi, you can download this codec from here:
http://www.digital-digest.com/software/download.php?sid=1052&ssid=0&did=1
After you have installed this you can play dvd in the windows media player.
And don`t mess with the settings in this program.
You can download the latest drivers from here:
http://www.foxconnsupport.com/download.aspx?models=en-us0000073&category=C000000001&series=en-us0000003&keywords=&sort=Drivers
Have patience the page takes time to load.
You may have to install this:
http://www.java.com/en/download/
http://get.adobe.com/flashplayer/
There is also a another player you can download and install:
http://www.videolan.org/vlc/download-windows.html
This player plays anything.
Hope this will help you.
Aug 25, 2011 | Foxconn 760GXK8MC-RS Motherboard
Feed dogs don't feed evenly
are they clean? give them a good brush clean regularly with your little brush in the sewing machine kit.
However, if there seems to be an issue with feeding and the stitch formation, then the timing could be out and it may need a professional service.
Jun 08, 2011 | Sewing Machines
URGENT .. really need help sir.. my Printer Canon MX328, don;t want to feeding the paper. i don't know why . and sometime if the printer can feeding, 80% gonna be jammed. please help !
From your description,it seems that other material present inside your printer and blocking the paper path. Sometimes,broken paper feeder indicates the same way. I recommend you to bring your printer to the nearest service center unless you are quit familiar with assembly and reassembly of this printer.
Source:
Printer Clinic
Download Instant Manual
Feb 19, 2011 | Canon Office Equipment & Supplies
Paper won't feed in
Look down into where the paper goes into printer in the back, usually there is something stuck inside autosheet feeder.
Oct 27, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
EPSON STYLUS PHOTO RX425, PAPER PROBLEM
disconnect the printer from the computer:
>manually feed paper using the paper feed button.
>observe, if the printer pulls only one side of the paper then it´s a hardware issue
Jan 01, 2008 | Office Equipment & Supplies
Using window XP OS with Lexmark Z 33
Is the file data getting through to the printer. Check settings/printer/ right click OPEN. You should see file ready to be printed. Does the paper feed work? Have you downloaded the correct drivers?
Check connections to the printer and PC. Does on off switch on top of printer work correctly.
Dec 21, 2007 | Lexmark Z33 InkJet Printer
Dell Inspiron 2650 Notebook Logo
32 people viewed this question
Alun Cox
