MANUALE D'USO DAEWOO LCD DLT-19W4T - Computers & Internet
ginko
  • 19396 Answers
SOURCE: ho perso manuale di uso e manutenzione posso averlo on line ?
Clicca il link qui sotto per scaricare il manuale in Italiano:
Download italiano Libretto d'uso
Qui c'e anche la pagina di supporto Miele.
Non dimenticarti di votare adeguatamante la mia risposta, se questo ha risolto il problema vota blu, se ha aiutato blu, se non e' di aiuto giallo, il rosso e' per chi ti insulta.
Io direi che se cercavi il manuale qui il blu ci sta'.
Ciao, e in bocca al lupo con l'asciugatrice.
Posted on Feb 27, 2009
SOURCE: daewoo lcd dlt 20w2
Hi this is warjis ahmed,
I can solve your problem of DLT-20W2
My email> warjisahmed@hotmail.com
Posted on May 01, 2009
hazelgrace
  • 340 Answers
SOURCE: perso manuale di uso singer
Buscar en la pagina web de Singer
http://www.singerco.com/accessories/manuals.html
Introduce 4830 y hacer clic en search.
En el siguient pagina hacer clic en free download!
Solo esta disponible en Ingles, Frances y Espanol.
Espero que este ti ayuda.
Look on the Singer website.
Type in 4830 and click on search.
On the next page click on free download!
It's available in English, French and Spanish.
I hope this helps!
Posted on Oct 04, 2010
ekcnoel
  • 998 Answers
SOURCE: manuale d'uso del dvd recorder
Sir try to check this link http://www.manualsonline.com/search.html?q=dr300&submit.x=15&submit.y=20 good day and best regards.
Posted on Aug 12, 2011
SD Tech
  • 14553 Answers
SOURCE: electrolytic capacitors on daewoo DLT-3212
This sounds like a very common issue.
If set is hard to turn on (have to try several times) but will eventually turn on here is what my guess would be.
Every set has a standby power supply that is running 7/24 if the set is plugged and it supplies voltages to the remote circuit that turn the main power supply and the set hence ON.
This is an area where companies cut corners by using lower rated caps. By this I mean standby usually supplies under ten volts to to trigger the set on----what they do is use a filter capacitor/s rated at say ten volts max in a circuit with 9 volts----With the standby on all the time the filter caps (electrolytic caps) dry out inside and fail.
The problem usually begins where you have to turn set on one or two times and gradually gets worse---takes longer and more tries to get it to come up.
Once its on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of the capacitance) as they get hot===hence once on it will seem ok.
The beauty of this problem is most of them happen when the set is a year or two old and all you have to do is look at them.
They are generally black and round and vary in size---they have two connections on each: a plus and a minus---easy to replace.
The tops are silver and metal looking with creases in them and if bad in this way they will be puffed up on top----the tops must be flat and perfectly so.
If this is your problem once you id them by location(make a drawing of them) you will find the plus and minus marked on the board as well as a location number for each.
Here is the critical part--on side of each cap the value is also marked like 220 uf 10vdc= 220 microfarad at 10 volts DC (maximum working voltage) if you find for example 6 puffed up and all are 10 vdc replace with same value but go up to at least 16 volt or higher rated caps.
The only issue is when you go up in voltage rated value the cap is larger so sometimes a issue of space to fit them in the board.
The reason they cheapen these sets this way is if 10 caps and you make 25,000 sets the difference in part cost for those is enough to be important to the maker.
They do not care as long as it lasts the usual 1 year parts warranty.
I have taken the time to be long winded because this really sounds like what your problem may be.
see attached photo of typical cap and if you have questions or need advise let me know---I also have a blog just started for experts here and people with questions sd-tech.blogspot.com
Posted on Mar 20, 2012
Tip
DLT-32C3FTB
Hi.
This comment applies to Daewoo DLT32C3FTV. The system had in list only the model DLT-32C3FTB . Parts for the smaller model DLT-32C3FTB are available from the same sellers listed below. Troubleshooting is the same.
The stand by light flashing means that a fault had been detected, and the TV protection circuit had started.
Whenthis happen, the protection circuit will shut down all PSU highervoltages, keeping the low +5V to supply the flashing led on, and warnabout the fault.
The TV does not respond to control when in protect mode.
All you can do is checking all connections, and leaving the TV disconnected for a while, to drain charge held on PSU capacitors.
A short in a cable or connector will also cause the unit going on protection.
You can follow the instructions on this article, it refers mostly to DLP, but the troubleshooting is the same on LCD TV2_bing.gif: Why my TV does not start up and remains in.
If you have done that already, that means that there is an internal fault.
Inthat case the best thing to do is contacting manufacturer at the numberlisted on the owners manual, and getting a quote on repair.
Onan LCD like this there are only few parts, a main controller, aninverter, a PSU board, an audio board, an LCD controller board, abutton and IR assembly, cables and the display.
The parts must be accessed and tested by a technician.
If the unit is less than one year cold, the repair will be covered bymanufacturer. In any case, if the TV does not wake up from protectmode, then it is faulty. Always better contacting Daewoo at the numberlisted on the owners manual.
Parts are available from Daewoo. A spare PSU, that is a common fault, is about £60 in UK. Here the spare:
Power Board FEL-3226H Daewoo DLT32C3FTV . Naturally that is not necessarily the fault.
Try first the troubleshooting procedure suggested above. If that does not work, contact Daewoo.
on Feb 11, 2010 | Daewoo DLT22W4T 22 in. LCD TV
DAEWOO LCD DLT-46u1FH vertikal dark line and darker on one side.
Check all the flat cable connections in between T'Con board and LCD panel. Re-seat all of them. Any loose connection to these wires to sockets can cause this problem.
Jul 22, 2012 | Daewoo Televison & Video
Dlt-20j9t lcd tv completly blocked
Is the green light on? Power supply board has a know problem with dried out capacitors
Aug 15, 2009 | Daewoo DLT22W4T 22 in. LCD TV
My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Apr 22, 2009 | Daewoo DLP3212 32 in. LCD Television
Ho perso manuale di uso e manutenzione posso averlo on line ?
Jan 05, 2009 | Miele Novotronic T230C Electric Dryer
Daewoo lcd dlt 20w2
Oct 29, 2008 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
Computers & Internet Logo
David Payne
David Payne
