Question about Toshiba MD24F12 TV
Need IC - THOSIBA - 20N1TIV
Hi..... Need contact details at india - chennai (or) coimbatore. to get a ic for the above mentioned TV model. since the tv's ic was damaged from April. Regds...........Sikamani.
    President:
  • 3,130 Answers
Try this www.toshiba-india.com
Posted on Jul 18, 2007
SOURCE:
I forgot lock code. Model Nokia 6681 IMEI -355660/00/330782/6 FCC id- LJPRM-57 IC - 661E-RM57
.www.silickonmobiles.com call us for unlock 9842209546 in chennai, trichy and coimbatore..........
Dec 27, 2010 | Nokia 6681 Cellular Phone
In chennai free kalaignar tv sound not coming i changed sound ic an 17823a still sound not coming ples sen me the detail of this sub!!
you replaced the power amp ic before that you need investigate the condition of power ic and it's very simple when you terned on the tv set you can hear the small pop noice from the tv speaker means the power ic is good other way is just tuch the screw driver to sound if output stage you can hear the DERRR sound from the speaker
if it ok pls check the mute transistor
Aug 27, 2010 | Televison & Video
Flat line on Toshiba tube tv
It could be the vertical output IC, but there may be other possible causes which include:
- bad solder contacts on deflection yoke connectors or dirty connector contacts (on the circuit board and / or on the picture tube neck)
- bad solder contacts on the vertical output IC or associated components (check for little cracks in the solder around the pins, these are so called "cold" or bad / broken contacts)
- power loss to the vertical output IC - check for any burned resistors or other components around that IC, assuming you know which one it is - see which ICs are connected to the wires going to the deflection yokes (coils) on the picture tube neck and check them well.
You need to resolder any bad contacts, clean any dirty pins on the connectors and replace any burnt out components (assuming you can still determine the type or value of the component).
Since you mentioned the problem occurs once in a while, this means that the IC probably fails when it warms up, which can often happen if there are loose connections or bad solder contacts.
Anyway, it could turn out to be a faulty IC, i just suggested a few other things that can be fixed quite easily, and possibly without the need to replace any of the components.
regards
3rq8 (Triarcuate)
Sep 09, 2009 | Toshiba 27AF41 27" TV
We are using AIWA TV with 21INCHES TV with a
the model you have given was assemble in the philippines, and i was the process engr. then. i will try to look on my kits if i do still have a spare system ic.
Aug 04, 2009 | Televison & Video
The television stays on stand-by
You didn't mention comprihensive details (e,g: model number if its on st-by does the led blinks in a specific number of times) Anyway there must be two possible causes of st-by
1-First problem could be the remote/remote censor
2- second problem could the the malfunction of EPROM (memory IC)
3-Third cause could be the system IC.
Please contact any expert nearby.
Thanks for using fixya.
Jul 24, 2009 | Televison & Video
Transcend Service Center........
Transcend does not have any service center in India!!!! They do all their warranty related work through their distributors. You need to contact their distributor in direct way.For distributors click on the link below:
http://www.transcendusa.com/Contact/CuPartner.asp
For online tech help click : http://www.transcendusa.com/Contact/CuTechSupport.asp?LangNo=0&tCountry=43
Nov 25, 2008 | Transcend T.sonic 610 MP3 Player
Bush 29" Flat Screen TV IN INDIA CITY OF CHENNAI NEEDS REPAIR.
Please contact below address for Madras branch as they are authorised Bush service centre
Location : U/12 A, Yogi Complex, New Rander Road, Surat - 395009 Phone : (0261) 3066848, 6548278 Regards//Ravin//London
Jun 13, 2008 | Bush 2871NTX 28" TV
A bright line on the screen
A line running across the screen like that and then returning to a picture I would guess is the vertical IC has some poor solder joints. The vertical IC in that unit IC401 is an LA78041 a seven pin IC that is mounted to a metal heat sink. On the foil or under side of the board take a careful look at the pins of that IC and any that look suspicious carefully re-flow some solder over.. Careful not to keep your iron on the pin too long.. And if have to re-solder several take some time between them to allow the IC to cool so you don't damage it.. Good Luck Bill
Jun 10, 2007 | Toshiba 27AF41 27" TV
Toshiba MD24F12 TV Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
