Question about Grilling
I have a grillrite gas grill, do you have to have briquettes
3 Suggested Answers
  • 8 Answers
SOURCE: Do I need to use Briquettes with this grill?
No, this grill does not need lava rocks or Brickets.
Posted on Jul 02, 2008
jyackle5
  • 8197 Answers
SOURCE: using ceramic briquettes with lp gas grill
Many people enjoy using Lp/gas grills for their ease of use and efficiency. Frustrations caused by flare ups and hot spots encourage the use of a wide variety of briquettes and other products. Ceramic briquettes are most commonly used because they provide an even heating surface and last for several uses.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
  1. "SOOC" is Copyrighted by Flickr user: Robert S. Donovan (Robert S. Donovan) under the Creative Commons Attribution license. jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.co.uk/images/a05/8n/jr/should-use-briquettes-gas-grill-1.1-800X800.jpg'); }); Types
  2. Gas grills most often use ceramic briquettes, lava rocks or, more recently, ceramic tiles in order to distribute heat. Ceramic briquettes come in the traditional shape, lava rocks are similar to those used in landscaping, and tiles only differ from briquettes by shape. Traditional charcoal briquettes can be used, though they maintain several disadvantages. Use
  3. Place briquettes, tiles, or lava rocks in a solid layer on a screen between the heating element and the grill surface, making sure to leave space for air to circulate. Light the grill and check to make sure that all areas of the heating element are covered, filling any empty spaces. Advantages
  4. Ceramic briquettes, tiles and lava rocks all serve the same purpose. The advantage comes from their ability to reduce flare-ups and hot spots. They can also be used several times, minimizing set-up and making cleaning easier. Traditional charcoal briquettes are cheap and easy to find. They also provide the smoky flavor associated with traditional charcoal barbecuing. Disadvantages
  5. Ceramic briquettes, tiles, and lava rocks are not as easy to find as traditional charcoal briquettes and are more expensive. Traditional charcoal briquettes do not repel run-off from food, but rather retain it, causing hot spots and flare ups. Charcoal briquettes also need to be replaced after each use and are harder to clean up. Warnings
  6. Any additional product placed inside a lp/gas grill should not come in contact with the heating element. Doing so can cause increased stress to the grill, as well as clog vital gas ports. Always maintain a clean grill. A buildup of old briquettes can cause inadequate performance.
Posted on May 01, 2010
How much ceramic briquets should be used with this grill
You might try googling "flavorizer bars" and see if you can find the right length to fit your grill. Weber makes these for their gas grills, and they are much better than using lava rocks, ceramic briquettes or tiles. If the bars are too long, you can cut them down to size with a hacksaw. Well worth the extra work as they are far superior to the others.
Apr 09, 2015 | Grilling
Char glo indoor gas grill
leave at least 1/4 inch between briquettes. sometimes clients will pile-up briquettes hoping to make the grill hotter or more efficient but the briquettes can become an impediment to heat circulation which will cause heat to spread low. this usually damages the module and control valves. A single layer with small space between each briq is sufficient.
Oct 29, 2013 | Thermador Grilling
I have a used Thermos 2000 Millenium Gas Grill. Is there supposed to be charcoal on top of the burner cover? The charcoal was there when I got the grill. Thank you.
That's not charcoal or shouldn't be. It's Lava Rock Briquettes. If you want to replace or refresh them. you son find the, at most hardware stores and homes centers that sell grills and accessories.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Sep 04, 2011 | Grilling
A small wire from under the grill became unattached. I can't see where it reattaches and obviously the grill will not light. However you can hear the gas go on when I open the gas value.
If the wire is attached to the igniter behind the front panel, the other end has most likely come loose from the electrode that provides the spark to light the burner. You most likely will have to remove the cooking grates, flame tamers/briquette grates to get tho the electrode.
Jul 17, 2011 | Char-Broil CharBroil 4637318 Grill
Do I need briquettes for my weber silver grill
No, you don't use briquettes with a charcoal grill. Charcoal is slow to heat up any way, adding lava rock (briquettes) would make it even slower and hard to keep lit. However, its OK to add cooking wood chunks after the charcoal has heated up, to add a smokey flavor.
Happy Grilling!!
May 24, 2011 | Weber One Touch Silver Charcoal Grill
Using ceramic briquettes with lp gas grill
May 01, 2010 | Ducane 30400040 Stainless Steel Grill
What type of briquettes can be used in this grill?
lava rock, as is used in an outdoor gas grill.
Feb 03, 2010 | Gaggenau VR 421 Indoor Grill
Bynasty BBQ - Need briquette trays; left, right(
They have them at DynastyStoves.com/parts.php
30 inch models need one notched and one regular tray. 42 inch grills need two regular and one notched. they have the briquettes too.
Jun 30, 2009 | Dynasty DBQ-30 (LP) Grill
i had the same question about no briquettes and still haven't gotten an answer!! The food doesn't really taste like its grilled outside on a grill! Can you please let us know!!
Apr 19, 2008 | Uniflame FG2204C Grill
Grilling Logo
27 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
