Question about Amana ALE643RB Electric Dryer
Dryer heat output is 148, but takes several runs to dry clothes
I have an amana ALE956EAW electric dryer, however, I can't find an user's manual for the model #. I recently had the dryer checked and was told that the heating output was 148. However, drying a load of clothes takes nearly 180 minutes. What could be the problem, and is there a manual, and has this model # been discontinued?
I had the same problem. Turns out the length of the "exhaust pipe" was simply too long (our laundry room is in the middle of the house). I installed a pressure-activated booster fan in the exhaust ducting and it all works great now! The "pressure" comes from the dryer's fans. As soon as the dryer starts blowing in to the exhaust, the booster fan comes one. Have had this installed for several years now. Other than having to clean the booster fan "blades' every couple of years, no problems whatsoever.
Posted on Jan 17, 2010
You most likely have a ventilation problem somewhere in your exhaust line. This can be very dangerous and a fire risk. You need to do a thorough check of your vent pipe and make sure it is clear and the exterior trap door is working freely.
Posted on Jan 27, 2009
My electric amana dryer heats up but does not seem to blow the heat around and the lint is only gathering at the bottom of the lint trap, so it takes forever to dry my clothes. What do I need to do?
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Amana ALE230RAW Electric Dryer
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
Heats up but takes several cycles to get clothes dryer
Check for a restriction in your exhaust vent. not just behind the machine but all the way to the outside vent,should have good warm airflow at outside vent. With no good air flow you have no way to get rid of the moisture. and all you will end up with is warm moist clothes. this can happen slowley happen over time and next thing you know it takes several cycles to dry the clothes .it cost a lot to dry them this way
Aug 08, 2010 | Amana NED5400TQ Electric Dryer
Dryer is not heating up
This is a simple dryer design. The limits and heater are all mounted on the heater assembly. 9ce9b7a.jpgGet the front off and take a look see. AMANA DRYER
May 04, 2010 | Amana NED5500TQ Electric Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Amana dyer model ale956eaw, won't heat up, all
if all other operations of your dryer are ok possibly your heater element or thermostat are faulty also there may be damaged wiring you will need to look closer and own a multi meter to check properly keep me informed of how you went
Nov 07, 2009 | Amana ALE956EA Dryer
Not drying my cloths . runs but there is no heat
Since the unit will run but won't heat...
The following are things that could stop an electric dryer from heating:
bad heating element(s)
loose, corroded or burnt wire(s)
thermostat(s)
thermal fuse ( not all models )
motor heat switch
timer
selector switch
The older the unit the more likely it's heating elements or thermostats
Sorry....this can take some time to diagnose
Apr 10, 2009 | Amana ALE866SB Electric Dryer
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Amana dry wont dry
partially bad heat element. some models have a double element maybe half of it is burned out
Nov 17, 2008 | Amana NDE2335AY Electric Dryer
Dryer runs but with little heat
Generally whilpool dryers heat of dont heat.. output should be around 150 .. i would check hose to make sure not clogged or just run without hose and see if that makes a difference... post if need more help
Oct 29, 2007 | Whirlpool LER4634J Electric Dryer
Amana ALE643RB Electric Dryer Logo
317 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
