Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Picture fades to blue after a minutes
TV comes on - good sound good picture - then after a few minutes it fades to blue - good sound - blue picture
took the back off and watched - after a few minutes the red and green tubes dull and I'm back to blue
How do i pull off the front bezel and check the heaters under the tubes???
  • larryr1960 Jan 29, 2009
    how can i see the service menu if all i can see is blue? Why would the red and green tubes go off?
  • 153 Answers
There wil be a is chip iv ur tv board backside in that check the convergenve ic tat might be burnt out
Posted on Jan 27, 2009
    Genius:
  • 1,550 Answers
It is convergence problem in your tv you need to replace the convergence IC .
The convergence setting is not proper in your tv . You need to access convergence setting through service menu .
  • SAM ANDERSON Jan 29, 2009
    The problem could be on your SSB board .But mostly it tends to be convergence issue in your tv .
Picture fades to black
Find the vertical IC and check for very small cracks on the solder joints of its pins and resolder (approx. 10 Pins). Also check in the same area for a 1 micro farad at 50 vdc capacitor that goes bad and replace it.
Dec 18, 2013 | Toshiba CX32F60 32" TV
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
Picture comes on then fades to blue
Check the info from this website to see if you are able to fix your TV. You should turn the blue screen control down slightly counterclockwise. If that did not work, then more likely you have a video amplifier IC defective or a blue CRT.
Dec 19, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue screen
This is easy to fix, pull off the front grill and turn the bottom left trim pot anti clockwise until the picture comes back. I am asuming the picture there and then it fades to blue. There is a step by step instruction on how to get the whole thing apart http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 15, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40
sounds like the tuner may be going out on the set.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
JVC Projection TV shuts down by itself.
47" JVC TV TURN THE POWER ON THERE ARE SOME BLUE LIGHTS THAT COME ON BUT NOT THE TV. THEN AFTER A FEW SECONDS THE BLUE LIGHTS FADE AWAY.
Dec 15, 2007 | Toshiba 50H81 50" Rear Projection...
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
