Question about Welding Tools
Changing tips on a weller wd1 wp80 soldering iron
Cannot figure out how to do this. In our attempts to remove the old tip, it has broken off about 1/4" inside the barrel. There seems to be no obvious way to remove the old tip. The new tip, however, appears to have a snap ring groove near the base.
5 Suggested Answers
  • 33 Answers
SOURCE: I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Posted on Aug 30, 2010
  • 1514 Answers
SOURCE: i have a weller wp35,
The WP35 is strong enough and the ST3 tip will do the job. The larger tips are really only for covering larger items but when soldering it's the wire you heat, rather than the solder, and melt the solder with the wire. The tip will reach the same temperature regardless of the size and while the larger tip might heat the wire a little faster the difference would not even be noticeable.
Posted on Jan 30, 2011
SOURCE: I bought an old Weller solder iron station at a
The TC201Z is a zero crossing switch version of the TC201T. The two handles use the same tips which are the Weller PT series.
Posted on Sep 10, 2011
SOURCE: Weller WD1. At power on
Found the solution!!
Step 1) Turn unit off. Hold 1, 3, up and down. Turn unit on. Wait till you see -1-, -2-. Then release the buttons.
Step 2) Hold again 1 , 3, up and down. Wait thill you see FCC, FSE. Release the buttons and press the up button.
Your system on now resetted and will heat again.
Posted on Oct 24, 2011
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Dennis
Apr 15, 2017 | Weller Welding Tools
Hello all. I just began having a problem with my Weller WD1 Soldering Station. It powers on fine and the display works, however no matter what temperature the display says it is set to it will not hea
You might want to check the iron itself with an induction power tester to see if it is getting any power to the tip. This type of tester doesn't require any dis-assembly just close proximity to energized circuits.
Feb 09, 2015 | Weller Welding Tools
What tips does the weller wd1 use?
I believe it takes the LT S E R I E S tips for the W S P 8 0 Soldering Pencil.
http://www.digikey.com/Web%20Export/Supplier%20Content/Cooper_72/PDF/CooperWeller_Catalog550543.pdf?redirected=1
has a catalog with the part numbers for the different types of tips.
Nov 04, 2013 | Welding Tools
Solder tip is worn out need to replace, how do I remove the old one weller model W-TCP
The barrel to the soldering iron has a nut on it and the nut unscrews and the whole barrel comes off. The tip then comes out of the barrel.
Jan 13, 2013 | Cooper Industries Weller Field Soldering...
My Weller WMRP soldering pencil has become intermitent, is ther any way to open and look for broken solderings in it?
The problem is caused by the ceramic heating element built into the iron, it becomes intermittent over time and cannot be accessed.
Feb 24, 2012 | Welding Tools
Weller wd1XXX with WP80 not heating with - - - error on display HELP?
There is ceramic heating element that gives problems, and there is some kind of transformer or coil below that. I had no success in repairing the iron so I ended up replacing it. My soldering station saw two iron replacements over the years, I checked to make the station was putting out the 24volts required.
Dec 03, 2011 | Welding Tools
Weller WD1. At power on screen says "OFF". The 3 preset temperatures are still displayed. Tested with a working lead and soldering tip, OK.
Just press UP/DOWN at the same time quickly. If you hold them down you will get to the menu but just pressing them and releasing them will turn the station back on.
May 31, 2011 | Weller TC201T: Soldering Iron For Wtcpt,...
How to remove a weller sp 80 tip
Just loosen the screw in the barrel near the tip, then rotate while pulling the tip out. It shouldn't be necessary to remove the tip unless it requires replacement. Hope this helps!
Oct 30, 2010 | Weller SP80 Soldering Iron
Replacing Tip Weller SP40L
It just corrosion. Take a pair of slip-joint or grip pliers and twist the tip back and forth until it release.
If necessary use PB Blaster® or WD-40® for the corrosion.
MT10 1/4"/10mm diameter replaceable nickel-plated copper tip
Mar 24, 2009 | Weller Marksman Iron 40 Watt SP40L
Welding Tools Logo
219 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
