Question about Juster AC-691 Computer Speakers
Need the specs on adapter for JUSTer dc-691p speakers..... I lost the cord that you plug into the wall socket but I still have the speakers...want to get something that will replace the cord but I don't haveI specs....voltage..milliamps...etc
  • Anonymous Feb 28, 2009
    I am missing the AC Adapter used with the JUSTer HI-Fi Speaker System, DC-691P.
Model: PPI-0930-UL
INPUT: AC 120V 60Hz
OUTPUT: DC 9V 300mA
Polarity: Neg.outside, Pos.inside
Posted on May 19, 2009
I need a class 2 power Supply ac/dc adaptor
Shop for I need a class 2 power S... on Google
Phihong ? Wall Mount AC Ada...
$4.68
Mouser Electr... United Security Products AC2P
$15.44
ELVESsupply... Mean Well ? Desktop AC A...
$13.10
Mouser Electr... Ac Adapter For Black & Decke...
$17.99
eBay Generic Ac Adapter Char...
$5.99
eBay Search Results
    Kastar AC DC Adapter Plug-in Class 2 Transformer Power ...
    www.amazon.com > ... > Car Chargers
    Amazon.com, Inc.Kastar AC DC Adapter Plug-in Class 2 Transformer Power Supply Cord Wall .... Provides power to your device in the event you may have lost or damaged your ...
    Amazon.com: Class 2 Power Supply AC Adapter 6V 200mA ...
Dec 14, 2015 | Computers & Internet
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
What is rating of Spin 50 Power Module. Lost mine
Should it be a power supply that outputs AC and converts to DC inside the speaker case, or is it a wall adapter the outputs DC straight to the built in amplifier?
Some speakers have the voltage and polarity for the plug on the back of the speaker where the power lead plugs in. As they are only small speakers of probably a couple of watts it may only need about 2 Amps or less. Higher current is fine as the amp will only use what it needs to work correctly but I would'nt go below 2 Amps.
May 06, 2012 | Labtec Spin 50 Computer Speakers
LOST A CORD TO MY COMPUTER SPEAKER SYSTEM MICROMEDIA SYSTEM. SERIAL NUMBER IS PN7000596, EJ 0192668 O THE SUBWOOFER. TWO SMALL SPEAKERS CONNECT INTO SUBWOOFER. LOST ONE CORD. CAN I GET A...
They usually use pretty standard audio cords, you can probably just get a replacement at your local Radio Shack. The only one I would be worried about is if you lost the power cord....if that's the case you need to be sure if you buy a different one that the voltage is the same as required.
Mar 08, 2011 | Boston Acoustics MicroMedia Computer...
Need spec and power supply for this set of speakers "Juster DC-691P"
Speakers (External, Powered), (Adapter, 9V, -Outer, +Center) Juster DC-691PASpeakers (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PA
Sep 08, 2010 | Juster AC-691 Computer Speakers
JUSTER DC-691PA SPEAKERS USE AN AC WALL ADAPTER. DO YOU KNOW THE POWER REQUIRMENTS FOR THIS SYSTEM?
Computer Speakers Juster (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PAYZNJ891701998
Aug 30, 2010 | Audio Players & Recorders
What is the power adapter needed for the Pro Juster 691Pa speaker system?
Aug 22, 2010 | Juster AC-691 Computer Speakers
What is the output voltage on the adapter for justin 691p speakers
Aug 11, 2010 | Juster AC-691 Computer Speakers
What dc output voltage does it take for my juster 692p
From any port on a powered USB hub, you can draw up to 500 milliamps at 5 volts. This gives two and a half watts to play with; the peak draw of the SP-692p probably won't exceed two watts.
Hope this initial info/idea helps.
Let me know for any clarifications.
Apr 06, 2010 | Juster AC-691 Computer Speakers
Volume
oh i see the first question was way to vauge to really answer. it sounds that this is a powered speaker meaning it requires that 12v that you are reading and wont work without it. i am assuming that the cord coming from the speaker is a male end that plugs into female if that is the case it will be difficult to find an adapter to plug into the wall as those have male ends as well. if there is a female plug on the speaker you should be able to find an adapter that plugs into the wall outlet(transformer) just be sure to match up all specs i.e. 12v 1.0a
Nov 19, 2008 | Compaq Presario 5000 PC Desktop
Juster AC-691 Computer Speakers Logo
3,502 people viewed this question
Top Juster Audio Players & Recorders Experts
Martin Murray
Victorman
Victorman
Rick
Are you a Juster Audio Player and Recorder Expert? Answer questions, earn points and help others
