Question about Stanley PC809 Inverter
800w stanley convertor indicates usb overload
Convertor will not charge the batteries and I can not find a reset or fuse for the convertor. There is a breaker for it but that is not the problem
If there is not a thermal overload reset on the convertor then it is an automatic reset built into the unit. When the convertor overloads and kicks off, it usually means that either something on the circuit has shorted out causing it to trip or you overloaded the convertor drawing too much power. Either way, if the convertor hasn't reset itself after a cool down period then more than likely, you convertor went bad and will need to be replaced.
Nov 13, 2014 | Coachmen 2011 Brookstone 366RE
How to charge jump starter
If the battery is real low, It takes about 8 hours to recharge it,
Dec 05, 2012 | Stanley Black & Decker Stanley J5c09 500...
Stanley 300 amp jump-start system status lights don't work. only low stays on
Sep 26, 2012 | Stanley 300 Amp w/12V USB Jump Starter -...
My stanley 300 amp jump-start system lights flickering when I plug it in to charge?
Apr 20, 2012 | Stanley 300 Amp w/12V USB Jump Starter -...
How do you put blades in stanley fat max extreme razor knife
Not sure exactly because I don't own one, but the review seems to indicate you push the blade positioner all the way forward, and push a release to remove the old one out the front, and then push a new own in until it clicks in place. With the blade positioner all the way forward.
But the review said it did not work well.
http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Feb 26, 2011 | Stanley Garden
My stanley 1.2 gal compressor immediately blows the new fuse when i replace it
You might just have an overloaded circuit, what else is on that line?
Jan 07, 2011 | Stanley Air Tools & Compressors
How to fix rockwood 10 in. 800w sub?
i would double check your connections also any fuses on the amp i have blown a few fuses on my amp haven't checked into the main reason for that to happen but its common if you don't have a big enough amp... assuming that the amp is getting overloaded. I would say you need a bigger amp like 1600watt or 1800watt
Jul 30, 2009 | Car Audio & Video
CATALYTIC CONVERTOR - BANK 2
You have a V6 engine, bank one is the row of cylinders on the passenger (right) side, bank two is the row of cylinders on the drivers side (left). Your codes indicate an inefficiency in the cat on the left side but this could be due to a bad O2 sensor or an engine that is out of tune and overloading the cat. This car seems too new to have a bad cat. I would change the plugs and the O2 sensor after the cat before going any further. The reason I say the O2 after the cat, it's the one that is critical in sensing cat efficiency. What is the mileage?
Mar 26, 2009 | 2005 Mitsubishi Galant
Stanley PC809 Inverter Logo
Top Stanley Electronics - Others Experts
Are you a Stanley Electronics - Other Expert? Answer questions, earn points and help others
