Question about Tools & Hardware - Others
Marbig stapler won't staple
I bought marbig staple as directed: No. 23/15, to staple thin books of 37 pages and two 200gsm card covers. The stapler worked once but won't work again. There is no jambed staple.
  • sandra phillips Jan 23, 2013
    I bought stapler: Marbig 90230, and staples: Marbig No. 23/15 for use in heavy duty staplers including Marbig staplers 90170 & 90165. But on useing, stapel went in first time only. There is no jambed stapel. The row of staples does not seem to be pushed toward the business end of the stapler. I have followed the instructions, but get nowhere.
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
brainyass
  • 242 Answers
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Posted on Oct 23, 2008
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Has anyone found substitute rexel titan No 37 staples for the rexel titan tacker gun yet. The No 88 staples although they fit the gun do not fire as they are not fine enough .The original No37 ones are...
Rapesco Part number is: S14082M3. I've used these without problem
apparently Rapesco has now changed to Tacwise and they are now sold as
Tacwise 0346 (Type 140)
Oct 09, 2012 | Office Equipment & Supplies
Our staples won't go all the way through . We
You didn't list the make and model of your stapler but if it's not driving the staples flush with the surface here are some possible causes:
1. The wood; If you are driving long staples into hardwood or knotty lumber you may have to use shorter staples to see how they set.
2. Stapler settings; Turning the air pressure up isn't the answer to driving staples deeper, it is only harder on the stapler. Most staplers work in the 90 to 120 psi range. The lower pressure you use the longer your stapler will last. Check/adjust the depth of drive control on the stapler to determine where the top of the staple is driven to.
3. Broke stapler; If it's not driving them to the proper depth but the level they are driven to is consistant, you may have a damaged piston o-ring/seal or the end of the driver is broken off. You'll have to go into the gun or take it to a service center to check these things.
Mar 04, 2012 | Air Tools & Compressors
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
I just bought a Black & Decker Powershot stapler Model 5700M. I am ready to use it, but I read the Warning on the side of the stapler. It said, "Warning: For safe operation, read instruction...
was going thru older questions and found yours. If you do not have a manual yet go to dewaltservicenet.com and on the left side type in model number 5700. It will allow you to download the instruction manual. In complete it is 12 pages long but you can define the pages for what language you want to print.
Apr 28, 2011 | Black & Decker 5700 Powershot Forward...
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
Tools & Hardware - Others Logo
244 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
