Question about Maytag Refrigerators
How do i level a maytag psb2151gr
No leveling screws or hex bolts like the manual shows and no screw down feet either.
Bgillespie
  • 89 Answers
SOURCE: MZD2766GES: How do I level the doors?
The door needs to be level, or the whole side of refrigerator. Pull off black strip at bottom front, there should be screws on either side to level the fridge. goodluck
Posted on Dec 16, 2007
  • 2920 Answers
SOURCE: leveling refrigerator
you might lower the front ones to get it level thats the only sloution i can come up with
Posted on Aug 27, 2008
  • 308 Answers
SOURCE: adjust height level on uneven floor
Yes, the front two "feet" of the refrigerator are used to for leveling purposes. Don't forget to level front to back, and left to right. Hope this helps.
Posted on Nov 26, 2009
hiltonjug
  • 612 Answers
SOURCE: how to level a maytag plus side by side
There is a bolt in the middle of the bracket that holds the wheel that you turn. When you tighten the bolt it pushes on the the wheel bracket and it goes down, bringing the fridge up. Loosen, it goes up bringing the fridge down.
Posted on Nov 27, 2009
  • 2468 Answers
SOURCE: MAYTAG MFI2067AES ICEMAKER NEEDS REPLACING
2 things possibly: check brackets and see if they need to be moved inward or outward as in they have bracket catches on the brackets so when you remove the screws the icemaker just doesn't fall off the wall of the unit,also check the center of the machine you may still have a screw holding the assy thats hidden
Posted on Feb 03, 2010
I have a maytag epic z washer and drier The washer sometimes shakes so much the machine moves 6" other times it works perfectly . It's on the second of our house ( our house was built 1909 . We had a...
Check under the machine and locate the adjustable feet. Screw the feet in as far as practical, the further the better. Feel the machine for steadiness and rocking and adjust the foot that shows clearance until it is firmly on the ground and the machine no longer rocks. Check that machine to see if it is level, with a front loader this is not critical, but it should rather not be out of true by a large amount, the important thing is that there must not be any movement on the machine's feet and the machine should not stand too high on its feet either.
Mar 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
Bottom drawer does not have a hard stop. Drawer will roll right off the door and on to the floor
check the level of the Dw per the instructions.. may need to raise the front up... If you take the front kick plate off( 2 screws) there are 2 white feet at the front... also phillips screws above(inset) that control the height of the back 2 feet.
Manual tells you where to place the level.. for plumb levelling the manuals stated to put the level on the front side of the cabinet( where the door closes on to)... on the vertical side. Adjust the front feet down, or the back ones upward( need to watch to keep the side to side level when doing this too...
Good luck
Oct 04, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
Trying to adjust headlights on a 2000 Plymouth Grand Voyager
On drivers side, Look for holes in rad support above headlights and you'll see a bubble level. Behind light housing you'll find small hex, or torx head screw just left and behind bubble level area. That's Horizontal adjustment. Now go over to right about 3 " from bubble level,just past where headlight mount is attached and look down hole for another hex, or torx screw head. That's vertical adjustment. Passenger side location will be obvious after finding drivers side adjustments.
Sep 19, 2010 | 2000 Plymouth Grand Voyager
How to level out the washer
the four corners have feet that simply screw in and out to level. Place a level on the top of the washer when adjusting these feet
May 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Leveling side to side, The manuel talks about an adjusting screw to raise roller up and down, but mine has no such thing. My model is: MFT2771WEM1
all should have to do is screw out the feet to the desired level and then run the jamb-nuts up to the bottom of the cabinet to keep the legs where you set them originally
Apr 11, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
Fridge is not level - it is higher at the front than at the back.
We had the same problem when our was delivered last week. I spoke to Samsung customer services.
They said the roller in the middle of the front is not meant to be there permanently. It is just a transport roller and should be removed once your fridge freezer is in place.
To remove it:-
- unscrew the two white plastic feet at either side of the front until they touch the floor.
- then place a flat end screwdriver in the slots in the feet and continue to unscrew them. They will start to lift the front of the firdge -freezer up until the front roller no longer touches the floor.
-keep doing this (a little bit each side at a time so the fridge -freezer stays level) until the roller is about 15mm off the floor.
- then get a small flat spanner and remove the two small bolts on the metal plate that holds the roller to the bottom of the fridge-freezer.
Once these bolts are removed the roller and plate will drop to the floor and can be removed.
Then using the screwdriver, screw the feet back in until the point when the front of the fridge-freezer is level with the back.
The whole process shouldn't take you longer than 15 minutes.
I asked Samsung why this isn't included in their instruction manual and they couldn't give me an answer which I thought was poor.
I do wonder how many Samsung RSH1 fridge-freezers are out there with the front roller still attached!!!
Oct 25, 2008 | Freezers
Unlevel freezer door pops open
first insure the whole unit is level do this by screwing down or up on the feet with a cresent wrench if thats ok and still have problem you can loosen screws on hinges and level manually most times screws have caps hiding them they just pop off good luck hope this helps
Aug 24, 2008 | Kenmore 62232 / 62234 / 62239 Bottom...
Kenmore 70 Series heavy duty washing machine
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Refrigerators Logo
26 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
