Question about Greenlee GT-11 Non-Contact Voltage Detector
Greenlee gt-11 light lights and alarm sounds but won't stop sounding so you can test a circut
2 Suggested Answers
uge44
  • 226 Answers
SOURCE: Boke End cap from Greenlee GT-11 Voltage Detector
You'll be lucky to find one as the product is inexpensive. Try this instead. A lot better design.
http://www.fluke.com/fluke/usen/products/categoryind.htm
Posted on Oct 11, 2012
Oct 11, 2012 | Greenlee GT-11 Non-Contact Voltage...
2005 tahoe rear access door ajar alarm won't stop going off
I HAD THE SAME PROBLEM WITH MY REAR DOOR TAHOE 2001 ., I TOOK IT TO THE MACHANIC AND IT WAS SO SIMPLE A FUSER UNDER HOOK . $8.00 FUSER ., IF I WOULD IT KNOW . I WOULD IT DONE IT MYSELF.-- REPLACE FUSER WHERE IT SAID --HORN- ITS UNDER THE FRONT HOOK... I END IT UP PAYING $120.00 FOR THEM TWO HOURS WORK...THE LIGHTS AND THE ALARM WAS NON-STOPPING MAKING NOISE..... RIGHT..????
Sep 20, 2012 | 2005 Chevrolet Tahoe
Car won't start.
are you sure the fuel pump is working? have you tested for a spark? these are the only things i can think of at the moment that would allow it to turn over but not fire. unless you have an alarm lock out that may be messing up.
Jul 22, 2012 | 2001 Mitsubishi Eclipse GT
2004 Camry won't start alarm. Sounds and lights
i thing something wrong with your car, you should use mvci toyota tis diagnostic tool check your car.
Apr 17, 2012 | 2004 Toyota Camry
2004 RAV4 won't turn over, do I need a new battery?
IT SOUNDS LIKE THE BATTERY IS DEFECTIVE, LOW BATTERY VOLTAGE WILL TRIGGER THE ALARM SYSTEM. ANY AUTO PARTS STORE LIKE AUTOZONE AND OTHERS WILL TEST THE BATTERY FOR FREE.
Dec 12, 2011 | 2004 Toyota RAV4
2001 aurora won't start at all. Hook batery up horn horn sounds and doesn't stop head lights stay on but nothing happens when the key is inthe ingition. No clicking or anything at all. alarm on...
The security system does not disable the starter, it only disables fuel to the engine. In the fuse block under the hood, locate the STARTER relay. Place your hand on this relay and see if it clicks while someone else turns the key to start...if the relay is ok then the starter itself is faulty. Good luck, i hope this helps.
Jul 11, 2011 | 2001 Oldsmobile Aurora
GT-11 Lights up when near my granite counter top ????----Also Nearly All Electrical Metal Items In House----When We Unplug Microwave Granite It Stops Showing Voltage ????----RICK
Grnite is SLIGHTLY conductive so if your counter top goes anywhere near live wires such as an appliance, you may sense it is hot with thaat detector. The stray field from the microwave is jumping onto the granite... HOWEVER please verify that your ground on the microwave is intact and returns to the third wire and has continuity to the case of your breaker box. If the ground is broken, that will certainly cause the indication. You can get one of those receptacle testers to test this.
ALSO NEVER trust the detector when safety is an issue. The device is "indication only" and it can be wrong for various reasons.
Sep 06, 2010 | Greenlee GT-11 Non-Contact Voltage...
Greenlee GT-11 Non-Contact Voltage Detector Logo
50 people viewed this question
Top Greenlee Measuring Tools & Sensors Experts
Wbix
Vuk B
Tom Chichester
Are you a Greenlee Measuring Tool and Sensor Expert? Answer questions, earn points and help others
