Question about Fine Digital FineDrive 400 GPS Receiver
STOCK IN ONE POSITION
HI. AFTER ENTER ADRES AND GET GPS SIGNAL,NAVIGATION
IS NOT WORK.JUST STOCK ON ONE POSITION AND REPEETING
"WASHING FOR GPS SIGNAL".
    Scholar:
  • 107 Answers
Try a GPS reset, exit navigation, click on setup, click on GPS reset. then restart navigation. check the gps status screen to make sure you are getting signals. if not, you could have a failed antenna or GPS receiver in the unit.
Posted on Feb 18, 2009
Hi I recently bought the Garmin 1490T GPS and have never used a GPS before. I was able to start up the GPS and connect the charger in the car and enter the home address. However I am a bit lost on how to...
Refer to Page 8 of your owner's manual:
On the main screen, touch "Where to?", then enter the state, city and address at the next screen. Once you've entered the information, touch the address and your unit will probably ask "Navigate to there?" and confirm... and off you go. You can save addresses to your Favorites list as well.
Jan 07, 2011 | Garmin nuvi 1490T GPS Receiver
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
Wont calculat route
sat nav needs a valid gps signal to start calculating route, even if it found entered address. Address is searched on built-in map, not live gps position. That means, sat nav may have problem with gps signal. Try to reset device to its factory settings first. hope this helps
Nov 01, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
My x3-t navigation system GPS freezes up
On most gps's that means it is time to reset the unit. This should force it to reload the sattilite catalog information and it should start working. Depending on the unit it can take up to an hour before it it works after rebooting while other new ones do it in a few miutes at most.
I believe this unit has a reset hole on the back so just insert somethign like a toothpick and reset it. Then place it where it can get a signal and let it do its thing. Should behave after that.
Oct 24, 2009 | GPS
Navigo sy885 not receiving gps signal
I had this with mine. remove the back of the gps and simply unplug the antenna re plug and try system. Worked with mine. Chris
Nov 04, 2008 | Tomtom Navigator 5 1H50.082 GPS Receiver
MIO P350 cannot get GPS signal
What navigation software you use? All navigation software need to install correct Port and Baud Rate for work - please check it in you software.
If you need help or professional GPS-consultation or unlock you PNA, update navigation maps - please ask
http://www.goodslowprice.com/en/unlock.htm
Mar 28, 2008 | GPS
How do I reset my magellan roadmate 760?
Your magellan roadmate 760 unit does not have any reset option.To over come the signal problem just follow the trobleshooting steps givven below .............
NOTE: If you are trying these steps from your vehicle, it is
Recommended to follow when the vehicle is in a stationary position.
Make sure that the device is exposed to the clear view of sky.
With the antenna pointing upwards, remove the antenna and then re-insert.
Swivel it up and down to make sure its securely placed.
wait for few mins and check the signal indicator.
Still not working,
  • Turn on the unit and select any user.
  • Make sure that the antenna is in the upright position and the unit has
    a direct line of sight with the sky.
  • Select 'Option' from the keypad.
  • Then select 'Configuration'.
  • Scroll down to select 'Diagnostics'.
  • Scroll down again to select 'Initialize GPS'.
  • At this point you would receive two options, 'Yes or No' - select 'YES'.
  • Now scroll down and select 'Set GPS Position'.
  • Enter your City, Street name and number at the corresponding
    prompts.
NOTE: The address that you are entering in the Set GPS Position should be the address at which you are at that point of time.
Feb 10, 2008 | Magellan Roadmate 760 GPS Receiver
Navigator map program says no signal detected
I had the same problem today. I restarted my palm, and the problem was solved.
Mar 09, 2007 | Tomtom Navigator Bluetooth GPS Receiver
Open Questions:
Fine Digital FineDrive 400 GPS Receiver Logo
206 people viewed this question
Top Fine Digital GPS Experts
ChuckyMo
drivealot
Iqbal Husain
Iqbal Husain
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
