New enviro e30 fireplace installed. Unit runs for approx 15 to 20 minutes and completely shuts down including the pilot
stpaulmercan
  • 8 Answers
SOURCE: Heater will not stay light
90% of the time, this problem is caused by either a clogged gas orifice on the pilot light's gas line, or by dust/debris in the pilot air intake, as stated by tradesman1. Start by blowing compressed air through the pilot air intake, both directions. If that doesn't solve the problem, remove the pilot assembly, then the pilot orifice, and blow compressed air backwards through the small orifice. The bottom line is that anything that causes the pilot flame to reduce in size will trigger the oxygen depletion system and that will result in the unit shutting itself off. This is a safety measure. Other possible causes: insufficient gas pressure to the unit, high altitude, defective thermocouple.
Posted on Jun 11, 2009
  • 3382 Answers
SOURCE: My propane fireplace pilot light goes out when the
I am just guessing but it may be set to low. The rush of air when it extinguishes could be blowing it out.
Good Luck,
Gilshultz
Posted on Nov 30, 2009
SOURCE: Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
Posted on Jan 02, 2010
  • 3280 Answers
SOURCE: Used LP tank on a vent-free fireplace
Hi is the tank empty sounds like it
Posted on Feb 13, 2010
  • 3280 Answers
SOURCE: Marco gas fireplace, pilot comes on, fireplace
Hi check pilot is clean , check the volts from the powerphile should be 300 to 500 mille volts ,seeif pilot flame is playing on powerphile
Posted on Mar 02, 2010
My gas fireplace shuts off after burning about five minutes - both main burner and pilot shut off.
Most fire place burners have an oxygen depletion sensor on them nowadays. If you can restart it after a while, a few minutes or so, and shuts off, it is probably the oxygen sensor. The owner lights fireplace and shuts the door, and the fire depletes the available oxygen and the fire will start producing copious amounts of CO which is a hazard. Most fireplaces have a fresh air supply available to provide combustion air but needs to be opened for the fireplace to work properly. Check the manufactures recommendation as to the proper installation of the fireplace furnace.
Hope this helps
Feb 05, 2015 | Heating & Cooling
I have a direct vent gas fireplace (MHSC series cdvsc7) that will light but will shut down after about 3 Minutes
you have trash in your pilot is not proper power light is not on please blow out are vacuum your pilot will sometimes help
Nov 29, 2014 | Heating & Cooling
Mod232le ssfbd32r
You need to clean out the pilot fixture or replace it.
Jan 27, 2014 | Heating & Cooling
Hearthmaster fireplace shuts itself off
So the main burner does fully ignite, but after a minute everything shuts off including the pilot? May just need the pilot cleaned
Sep 12, 2017 | Heating & Cooling
Marco gas fireplace, pilot comes on, fireplace fires up, after one minute the whole system shuts off. Why does it shut off after a minute?
Mar 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Jan 02, 2010 | Heating & Cooling
Marco gas fireplace shuts off
This an easy fix. What you must do is remove the dust from the pilot safety. I use rust buster from ace hardware to gently flush the hole. If ther is no hole just shoot a tiny drop or 2 into the pilot burner where the flame comes out. Blow it out (I use a piece of tubing). The problem is the dust drops the pilot flame to a point where it won't heat the thermocouple hot enough to jold the magnet and after 30 minutes she quits. THIS is a picture of where to clean the ODS pilots in your rig.
Oct 19, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
