Question about InFocus LP70+ Multimedia Projector
Lp70 projector Error message about Fans
After power-up I get an error saying one or more of my fans is not working, and it's shutting down. I took the unit apart and both fans are spinning and the filters are clean. Any Idea's ? The only other thing I have done latey is bought a new power cord for it. Could that make a difference.
  • 1 more comment
  • Abu5217 Jan 05, 2008
    Get the same message about the fans, although I can hear them running. I used to simply remove and replace the lamp, and the projector would turn on. Now, nothing. Get the message, and the lamp indicator LED flashes red. I KNOW the projector is not overheating.
    Thoughts?
  • kporter Sep 09, 2008
    I'm having the same problem, turn the power on, then an error message that reads, "Fan Problems. One or more of your fan have stopped."
    I cleaned the vents with a vacuum cleaner on low as the InFocus tech suggested, however, the projector still shows the "Fan Problems" error message, then turns off seconds later.
    Please help.
  • Alan B
    Alan B Apr 10, 2018
    i found that the "kickstand" front adjustable stand had broken off inside, and jammed the fan. removed broken parts, works fine !
I had a similar problem with an LP70. my fan was sticking.
So I opened bottom cover and pulled out fan cage, there are 2 fans.
you must know which fan not running.
If you found bad one remove paper label(yellow)
you can see 3 small holes.
using wd40 few drops to holes.
then manually turn using your finger cw and ccw few times
you can feel smooth turning now.
then relabeling to hole side.
reassemble unit.
power on.
Now you can enjoy with your projector.
Posted on Dec 24, 2008
    Problem Solver:
  • 6 Answers
I had one fan not working. So I touch the top cover off the machine and used a air can to blow out the dust. This seemed to free up the stuck fan and now it works without the error message.
Posted on Jun 21, 2010
I had a similar problem with an LP70. My Fan was sticking, but it would start after a bit, or if I gave it a push. There is a speed detect on the fans, so the fan may also not be spinning fast enough.
If you need to replace a fan, you can improvise.
I had to cut my dead fan out of the Infocus fan cage (I could not find a part for it), and then I found a fan online with matching specs with a yellow wire for the RPMs. I cut that fan out of its cage and epoxied it into the Infocus cage along with the other fan, and then spliced the wires onto the fan connector.
You need to add a circle of metal tape to the center of the fan motor like the Infocus fan had, to protect it from the heat of the bulb drying out the paper cover and letting dust again clog your motor.
Posted on Aug 02, 2008
I found that the kickstand adjustable front mount, had broken off inside, and jammed the fan. removed broken parts, works great.
Posted on Apr 10, 2018
    Genius:
  • 2,985 Answers
This I guess is more to do with the temperature sensor not functioning correctly. Dont know what can be done about it - as it would mean replacing the whole circuit board. Try the Technical Support on the InFocus web site. Of course if the machine is functioning- you could simply ignore it.
Posted on Jul 18, 2007
Sharp XR-30X starts up then shuts down after 30 seconds.
sounds like it is overheating -- are the fans installed pointing the correct direction, all spinning up well?
Jan 21, 2014 | Sharp XR-30X DLP Projector
Sony mhc- rg 55 MECHA ERROR disc spin then turn off
My mhc-rg 55 shelf system reports a Mech error when I turn it on (after rotating the CD tray to try to take up each CD twice ) Then is shuts down.... I took the unit apart and saw noting obvious... (Of course it was more difficult to reassemble and still doesn't quite fit properly.) But the problem persists. Looks like it over to the repairer. Sorry - No solution here
Nov 21, 2012 | Sony MHCEC99 Mini MP3 hifi system Shelf...
2 yr. old. worked great. Then started shuting down self changing setting to low. shortly after, shuts down after 3 min. no water collection, unit is hot. Took apart. Cleaned everything inside, and filter....
Robinson, it really sounds like the compressor is overheating. This may be caused by a low refrigerant gas in the compressor. Or the compressor's oil has leaked down. But, if you took the unit apart to clean it, I would think that you would have noticed an oily residue. If it is the compressor (other than needing to be recharged) it would cost almost as much to replace it, as it would be to buy a new unit.
At least with a new one, you'd have a one year warranty and more, if you purchase an extended warranty.
Hope this helped you.
Jun 02, 2011 | Dehumidifiers
Fan Failure Error
the temp sensor probably wore out when the fan did. just replace the sensor. usually located on the lamp housing or near the fans. looks like a transistor.
Sep 28, 2009 | Eiki LC-XG210 Projector Multimedia...
The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
Aug 18, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
I have a LG LHD45EL and the compressor works, fins chill but fan won't turn at all. I took it apart and cleaned the armature of the fan, Used a non-contact device to ensure electric is present in the...
let the unit cool down
with power on try sticking something in there to spin the fan blade
if it spins and continues to work it is a bad capacitor (little shiny metal can sometimes oval or round)
if it doesnt spin i would have to guess the motor is bad
hope this helps
Jul 29, 2009 | LG LHD45EL Dehumidifier
I just replaced a power supply, it has one fan instead of 2. Works great but now I get an error message saying it can't find the fan (which I'm no longer using), how do I get rid of the message?
replace the fan. it needs all the fans the projector was designed with to properly cool it down. without all the fans, the lamp will overheat and cause premature lamp and projector failure. the fan has 3 wires- ground, power and sensor. if the fan spins too slow or not at all, the projector will shut down to prevent damage.
so, replace the fan.
Jun 30, 2009 | InFocus LP70+ Multimedia Projector
Quick Flipoff
The air intake vents in the rear were clogged with dust. They needed to be brushed and vaccumed.
Oct 31, 2007 | Lasko 5132 Ceramic Compact Heater
Dell 1100mp "Temp" Light
I had the same problem and fixed it today. The fan is 70 x 70 x 20mm. I could not find the exact one, but 70 x 70 x 15 works just fine and I was able to find that fan at a Micro Center store for $8.99. The fans should be blowing air out from the front of the machine, not blowing in on the lamp.
Aug 24, 2007 | Dell 1100MP Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
2,781 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
