Question about Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594
Cub Cadet tractor choke problem
I have a Cub Cadet tractor LT1050 with snow blower. The engine has black smoke and does not run well. We changed the air filter and it is still the same. We found the choke does not have impact on engine whenever it is open or close. Maybe it is choke problem. How to fix the problem?
  • 10,865 Answers
There is a web site called mytractorforum.com which has a subcategory especially for the cub cadet. I recommend referring the problem to that site.
Posted on Jan 27, 2009
  • 1 more comment
  • Joe Hogan Jan 27, 2009
What type of oil do i use
(32 degrees and above, 30w oil) - (32 degrees to 0 degrees, 10w-30) - (32 degrees to -20 degrees below 0 and beyond -20, 5w-20 or 5w-30) Cub Cadets call for a low ash oil. it can be purchased at any cub cadet tractor dealership.
Jan 21, 2016 | Cub Cadet Snow Blowers. 28 in. Two-Stage...
Cant remove oil filter on Cub Cadet LT1050
grab the filter with a pipe wrwnch or drive a screw driver through it and turn it. good luck. Ron
Sep 14, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
White smoke comes from front of the mower when you first start the engine.
It just take a couple of starts to disappear - of course, if you removed all the creepers from inside
Aug 07, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
Where is the alternator located on an LT1050 mower
The 15 amp regulator is usually mounted on the side of the engine. It is a rectangluar plate with a wireing harness attached to it. Usally black in color.
Mar 04, 2012 | Garden
Cub cadet model LT1050, when i release the brake the engine wont stay running, but starts and runs fine if i hold the brake in
I believe the problem is a safety feature which is connected through the RMC, like the seat switch, just do a search for RMC on this PDF Manual it will show you how to check and what does what, Hope it helps and Good Luck Tim:
http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02100.pdf
May 20, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
Cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Mar 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594 Logo
401 people viewed this question
Top Mowtownusa Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Mowtownusa Electrical Supply Expert? Answer questions, earn points and help others
