Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
No Power on
I have a Sony TV model KV-2167MT Trinitron. I'm facing problem while switch on from front switch Standby LED blinking while press any switch Like Volume up down, program up down. but power not on. Any one have solution. please reply...
  • Jatinder Singh
    Jatinder Singh Aug 11, 2007
    I replaced 2sd1878 and PS801. it work 30 minutes after that transister get short again I change tr. but problem is same. Tr. 2sd1878 short after 30 minutes. I check output voltage 110V DC is normal.
    Please suggest.
Hi Arpi, I check 2sd1878 and PS801 found faulty. Replace both and now problem is solved. Thanks a lot. Jatinder Singh jatinderbajwa@yahoo.com
Posted on Jul 19, 2007
    Sergeant:
    Champion:
  • 326 Answers
Hello, please check the transistor 2SD1878 near flyback transformer and fuse PS801. Best regards, Arpi
Posted on Jul 18, 2007
Sony CRT TV not switching on power on LED keeps blinking
How many times do this standby LED blinks at one time switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty section circuit inside. Count it. If you wish to get more details, check this site. Pull up older posts there. Check this site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Sony CRT based TVs and all other models are given in detail. Check it and confirm.
Apr 08, 2013 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Standby light blinks and tv wont cut on
How many times the standby light at its front panel blinks? Count it. These blinks are fault indications. Check this link for more details about Sony Blinking codes. Count the blinks that occur once, after switch the TV On by its front panel power switch. Check it.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv sony wega dont turn on an the standby light blinks 16 times model KV-32FV310
Hello
Standby light on Sony TVs blinks 16 times is abnormal I thiks. It may come up to 8 blinks or so. You jsut switch off the set by AC mains switch at the front panel, switch it again with it and count the exact numbers. Never switch it On_Off by remote hanset.
If it happens even after this process, you just do the following
Press the following button on your remote control as stated
"Display"_"Channel"_"5"_"Vol Minus" [not plus] then "Power".
You may get "OVP" "OCP" "V STOP" etc displayed on the screen.
Just report the result to me through Fixya. Ok.
Nov 04, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony 2167 No power on
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Sony wega model: kv-32FS120 doesn't turn on
Check your power supply board and resolder the pcb, check the switching diodes and zeners.
Jan 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Aug 17, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
check video processor output diagram and signal amplitude if u can find video processor raplace it and try it must work
Aug 13, 2007 | Sharp 32C-240 32" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
148 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
