Question about Whirlpool 24 in. DU1050SS Built-in Dishwasher
How do I reset a Whirlpool DU1050 - Whirlpool 24 in. DU1050SS Built-in Dishwasher
Where is the reset button on a Whirlpool LER7620LWO?
No, there is no reset button on any whirlpool dryer designs, but if you unplug the machine for a few minutes then plug it back it in that should reset the machine back to factory settings.
Jun 21, 2012 | Whirlpool Dryers
My dishwasher DU1050 is stuck on Lock and I've
Hi! cccole
Dishwasher may be in bind. remove kick plate and make sure adjusters are not putting case in a twist, or pressing unit to tight to top of cabinets.
InMrFixIt.
Jun 19, 2011 | Whirlpool 24 in. DU1050SS Built-in...
I need a heating element (i think) for my whirlpool quiet partner 1 dish washer, but i need the model number and I dont have it with me, do you know the part number for the heating element that I need or...
Your Whirlpool Quiet Partner 1 should have its model number inside along the left side. Mine is DU1010XTXT1. Your heater part is original Manufacture # W10518394. Can be purchased for about $38.00 at
http://www.partselect.com/PS8260087-Whirlpool-W10518394-Heating-Element.htm?SourceCode=3&SearchTerm=w10518394
or order an after market heater element part # AP5690151 for about $33.00 at
http://www.appliancepartspros.com/whirlpool-heater-w10518394-ap5690151.html
Hope this helps!
Apr 04, 2011 | Whirlpool Dishwashers
How do i reset front panel on my whirlpool washer front load duet
Hi
Its a simple procedure to reset the Whirlpool Duet front load. Please press and hold the END OF CYCLE button for 15 seconds to reset. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The "clean" light blinks
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool 24 in. DU1050SS Built-in...
Light blinks 7 times on a du1050 whirlpool dish washer
I am having this problem now. I have replaced the circuit board, without success. There are many things that could be the cause, but I will be checking the door latch switches first. Also, if the main wash pump becomes clogged this could also cause the error code.
Aug 29, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Whirlpoool dishwasher not turning on model du1050
Make sure you have power to the dishwasher, check circuit breaker. If circuit breaker is ok, then remove toe panel at bottom front of machine, on the right hand side is where the power cable goes into a little metal box. Turn off circuit breaker to kill power to the dishwasher, remove electrical box cover and check to make sure that the wire nuts are tight. Reapply power and test. If still no go then remove tech service sheet from toe panel insulation, get yourself a multi-meter and start test individual components until you find the one that is bad. Hope this helps.
Dec 11, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool DU1050 will not start
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing. Unplug DW and remove console to gain access.
Jun 10, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Whirlpool DU1050 / Clean light flashes 7 times
Cmattson, This problem has been a real pain for owners of this model as well as us techs who repair them. There are a lot of things to check to get to the right problem. First, the water entering the dishwasher should be no less than 120 degrees. During the first 8 minutes of the initial wash cycle, the heater should be on. You can check this by dropping the toe panel and doing some tests. The element will be in the rear, so it can be difficult to get at unless you can pull the unit out some. Make sure the wires to the heating element are on. With a meter, you should be able to verify that the heater is receiving 120V during the first 8 minutes. The main board monitors the thermistor to see if there has been a rise of 4 degrees with water that enters below 110 degrees and 2 degrees with water that enters above 110 degrees. If it does not see this, it will drain and flash the clean light. The element itself should ohm out at 10 to 35 ohms. Other things you might have to check; The heater runs on the nuetral side of the door switch so you want to make sure the d/w is level and the door is closing properly. If the left door switch is not making contact, the element will not heat. Make sure all the harnesses are on tight on the control board. I have found in most of my calls on this problem it was a faulty heater. I've only had one case of a faulty thermistor. Best of luck on this..
Jun 10, 2006 | Whirlpool 24 in. DU1050SS Built-in...
Whirlpool 24 in. DU1050SS Built-in Dishwasher Logo
49 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
