Question about JVC LT-46AM73 46 in. LCD HDTV
Picture only showing in 480p not1080p
Even with the wii its still only 480p
In the wii setting why wont it let you switch the picture to 480p
You must have a component cable to switch to 480p.
Jun 18, 2014 | Nintendo Wii Console
Cannot switch the wii to 480p
Go to the menu setting on the tv and select video , then standard, then select the pixel resolution. 480,1080, etc. Select 480, and hit enter. The tv will adjust the picture quality. Hope this helps.
Jun 01, 2014 | Nintendo Wii Console
Where to start.....alright. I currently have a softmodded Wii console, and I recently bought third party component cables for it. The cables work fine under Standard TV resolution (480i), but when I change...
From the Wii Channels menu, click the "Wii" button on the lower left of the screen. From there choose: Wii Settings > Screen > TV Resolution. In this menu, click on the "EDTV or HDTV (480p)" option and then click "confirm".
Aug 07, 2013 | Nintendo Wii Console
I have hooked my wii up to a new samsung 42"
Make sure that you have switched the Wii to component video in the system setting menus. Once you have done that, you should have a color picture in 480p! Hope this helps!
Feb 27, 2011 | Nintendo Wii Console
I dont get the hd tv choice even though my tv is hd
The wii does not support HDTV resolutions, it only supports EDTV which is a resolution of 480p. If you want to get a clearer resolution than a simple scart interface you will need to purchase a wii component cable (you can get them off amazon/ebay) that has 6 jacks you can plug into the component slots on the back of the television.
Dec 31, 2009 | Nintendo Wii Console
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
Wii console to Philips HDTV Connection not working
In order to use the 480p (HDTV/EDTV) resolution, you MUST be using the Wii Component Video Cable. Any other cable will not display the 480p resolution, you have use the 480i (Standard) instead. You can order the Wii Component Video Cable through Nintendo's Web site. Using that cable, you can select the 480p resolution. Hope this helps.
Jan 26, 2009 | Nintendo Wii Console
What are the best settings for the wii on my sharp tv it is a lc-52x20e
Widescreen (16:9), and 480p
To use 480p, you will need to upgrade your standard Wii video cable to component cables to see the difference.
Jul 11, 2008 | Video Game Consoles & Games
JVC LT-46AM73 46 in. LCD HDTV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
