Question about RCA 20F420T 20" TV
Does truflat rca 20F420T model have a QAM digital tuner
  • 48 Answers
SOURCE: rca 14" truflat
really depends on the model. I've got a 2005 26" RCA truflat that has both digital and analog ota tuners--I can pick up off of rabbit ears OTA broadcasts, as well as via coax cable (cox cable) any of the unencrypted clear digital channels (QAM). Just can't handle the encrypted channels. If there are multiple coax inputs, check their labels--if labeled digital, likely that you've got a QAM digital tuner. Also, in the menuing system, channel scan--does it identify signal type as selectable digital/analog?
The surefire, get the model number, goto RCA.com website, download the user manual.
Posted on Mar 14, 2009
johnnydiode
  • 647 Answers
SOURCE: need a instructions manuals for RCA 20in 20f420t
Look for Product Manualswww.Product-Manuals.best-price.com
Posted on Oct 14, 2009
  • 72 Answers
SOURCE: my RCA TruFlat Model No. 20F420T shuts off at
HI,,
ITS NOT PROBLEM WITH TV TIMER...
ITS PRBLEM WITH TV AC TRANSFORMER WHICH IS INSIDE,,
ONE OF THE POSITIVE COIL INSIDE TRANSFORMER ITS SHORTING,,
APPROACH TV TECHNICIAN...
Posted on Nov 11, 2009
  • 12 Answers
SOURCE: I have a RCA Truflat
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Posted on Feb 18, 2011
SOURCE: rca 20F420T
I had the same preoblem with my rca model 27f520t truflat tv. I used a universal remote. When I first tried with the universal it would not work for me. The remote would turn the tv on and pull up the menu but the channel up or down and volume up or down would not, the light was flashing. I pulled up the menu and pulled a battery out and put it right back in and the menu stayed up and the light stopped flashing. I was able to go to preferences and turn off the fpa lock. good luck this was difficult to figure out and had me very irritated.....
Posted on Apr 17, 2011
Remove fpa parental lock
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Sep 13, 2014 | RCA Televison & Video
I have an RCA truflat tv. Model # 20F420T. A
I see no reason why not, you just have to connect those 2 and you will be fine.
Aug 27, 2014 | Televison & Video
I NEED A RECEPTOR CHANNEL FOR RCA TRUFLAT TV MODEL B27TF680 SERIE No. B406L914N
Many parts stores sell the fitting but it takes some real skill to install it and many times the tuner itself has the fitting built into it so the tuner has to be removed to attempt this.
what is your skill level?
Dec 19, 2012 | Televison & Video
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Feb 18, 2011 | RCA 20F420T 20" TV
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
My RCA TruFlat Model No. 20F420T shuts off at will. All the timers are set to off, any ideas?
HI,,
Nov 11, 2009 | RCA 20F420T 20" TV
Rca 14" truflat
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
Feb 06, 2009 | RCA 27F534T TV
Ready for nat'l digital transition?
If it is an older model (i couldn't find anything on it either), it most likely does NOT have a QAM tuner. Be aware that only the "un-encrypted" cable channels will be free otherwise you will have to buy or rent the digital box from the company to get the rest of the regular digital channels. The un-encrypted channels are like 71.2, 83.7 so you should know if you are getting those or not.
May 23, 2008 | Recoton Advent Advent HT3251A TV
RCA TruFlat TV
Be happy to explain how I fixed the problem.......please send $40.00 and I will forward the solution!!!!
Mar 03, 2008 | RCA Televison & Video
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
RCA 20F420T 20" TV Logo
46 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
