Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener motor doesn't work.
The original problem was my garage door opener motor would operate but the garage door wouldn't go up or down. I removed the metal housing cover and found that the gear and sprocket assembly was worn flat. I replaced the gear and sprocket assembly. I have a craftsman 1/2 hp chain driven garage door opener - model #139.53674SRT. After replacement and installing the housing in its original position I pressed the wall mounted switch to check to make sure the motor was functioning properly. Now, the motor doesn't work at all and the yellow SRT light flashes 2 times. What does it mean when the SRT light flashes 2 times?
Thank you,
Mark Chastain
mchastain@abmi.net
913-381-5426
  • dalihertz Jan 29, 2009
    I have almost the same problem...not sure the model...for about a week, the door would go up or down about quarter way and you had to keep pressing remote until it finally went either direction....now motor just makes a little buzz noise, but no movement....yellow light flashes two times periodically.
    This opener is about 16 years old....does it need a new one?
  • Vince Heuser May 11, 2010
    Is the trolley pinned against the stop bolt on the boom?
  • 118 Answers
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Posted on Jan 30, 2009
How to open the door if no electricity
Almost all garage door openers have a switch mechanism that will allow you to open the door manually. It is usually a pull cord on the motor or track. Pulling it down usually deactivates automatic mode. Just pull it up into position when the electricity comes back on.
Garage Door Repair in Jacksonville FL American Garage Doors LLC
Mar 17, 2015 | Building Materials
Wireless garage door opener works wired one doesn,t
Either the wall control has gone bad or you have a broken wire going to it.
Nov 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
We have an old sears garage door opener with one remote. it's model 139536006. There is no "Learning Button" on the motor, only a series of 9 code or dip switches that have to be set in one of...
You don't need the original switch positions. Make sure the row of switches in the motor unit are set exactly the way the remote is. The switches are normally marked + 0 -. Move all of them to the plus sign and try.
Jan 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Door will not move up or down,the drive motor just hums.
On the inside of the motor box, check to make sure the chain has not come off the gear.
Apr 05, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opens about one foot and remains there.
Check the door springs. You could have a broken spring. Also remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It is possibly stripped. This is a good time to release the door from the opener and operate it by hand to see just how heavy it has become.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opener will not opern
2 flashes indicate safety eye issue. Check you wiring and make sure it is wired correctly and check to make sure the eyes are properly aligned.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,729 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
