Question about Weber One-Touch Platinum 22.5 Grill
Need a replacement weber work table - Weber One-Touch Platinum 22.5 Grill
How do you remove melted plastic side tables from Weber Q grill plate
There are several videos on this on youtube. To remove the side tables watch this video at about 15 minutes in it will show you how to install. Reverse is easy. Press outward on the outside arms, press upward on table an it pops up, then slide table back towards grill an remove.
Weber Q3200 with Permanent Cart Assembly Guide
Jan 29, 2015 | Weber Grilling
I have a circa 2003 Weber Q and need to replace the ignitor pushbotton. It is housed in a circular tube on the left side of the grill. How do I remove the old one so a new one can be installed? It seems...
The igniter simply unscrews from front to back and then slides out. There is a lock screw off lock washer behind the head of the igniter.
Weber no longer stock the part, but you can find it at the following link.
http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/weber-igniters.html
In addition, I am including a link to your Owner's Manual which should help you on removing the igniter and installing the new one. http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q100120200220_OwnersGuide_41005_112706.pdf
Hope this helps you and Happy Grilling.
Jul 14, 2011 | Weber Q Grill
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
May 14, 2011 | Weber Genesis Silver B Grill
My weber spirit 310 igniter will not work. It does not click or make a spark. I have changed the battery. I did notice that the battery chamber was very corroded so I cleaned it out but still no click....
I suspect that the corrosion you found has taken it's toll. You will need to replace the the ignitor box.
if it's still under warranty, Weber may cover it. Either way, you can get the part from Weber on line. Make sure you have your Model #, Serial # of the Grill and the date and proof of purchase.
Feb 13, 2011 | Weber Spirit? E-310
Are there instructions to replace burners for the
Call Weber help line ask them to email the instruction to you. Generally they are really good about this
Mar 29, 2010 | Weber Summit Silver B Grill
My silver c igniter does not work..need to manually light..burners work..is new igniter worth pruchase? grill is almost 6 years old
yes replace it. you can call weber and they will send you one FREE just tell them whats wrong and the model number of the grill
Jul 18, 2009 | Weber Genesis Silver C Grill
Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Oct 06, 2008 | Weber Genesis Gold B Grill
Weber Seriel #QT0379827 MOdel #396000 Baby Weber
CALL WEBER! They'll get some information from you and then either help you fix the problem, replace the defective part or replace the grill. They've never failed to solve a problem I've had with a Weber Grill!
PFSmith
Aug 06, 2008 | Weber Baby Q Grill
Weber One-Touch Platinum 22.5 Grill Logo
42 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
