Question about Bushnell Yardage Pro Scout Rangefinder
It reads distance but not in M but in Yards how can I change it
  • 1,141 Answers
Very easy just press the red button on the bottom side
Posted on Nov 26, 2007
5 Suggested Answers
SOURCE:
  • 133 Answers
SOURCE: Bushnell yardage Pro won't read distances. Short
Bushnell has discontinued service on the yp500, yp400,yp800,yp800.yp1000. Basically all the units that look like this one. They will offer you a new unit at wholesale price.
call 800.423.3537 and ask them
mtg
Posted on Oct 08, 2009
  • 10865 Answers
SOURCE: Won't pick up long distance.
Hello. Push the mode button and the power button simultaneously for 30 second. This will reset it. If it doesn't reset it the first time try a second time as it generally does work. J.
Posted on Sep 27, 2010
jyackle5
  • 8197 Answers
SOURCE: Distance measurements do not appear past 50 yards.
Sorry there is no way to reset the rangefinder. You will need to call
Nikon Technical Support
8AM - 2AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Posted on Jan 10, 2011
tyhthrsmama
  • 9 Answers
SOURCE: I purchased a new LR
its a piece of ****, that happens when you arder through qvc. When you arder electronic devices for weights or measurements, first you must know exactly what you are looking at, make, model, and series,,, then read all of the reviews you can,, then go to a pro store-- (like our shop we are a pro archery shop) we refuse to work on peoples bows they bring in that they bought online, because half the time they recieved something that they did not order, they dont look like they did in the picture that the seller posted... always read reviews and ask the professionals.... I would return the item even if it was an auction, if you cant return it then ebay it-- but be honest when you post descriptions of the item, and the problems that you may be experiencing, trust me the buyers will appreciate it...
Posted on Jul 16, 2011
Have golfbuddy wtx how to change yards to meters.
5.1 Distance : Unit of Measurement This setting allows you to change your distance measurement from yards to meters. The default setting is set to yards. ? The tab next to "Distance Unit" in the tools menu, shows the current unit of measurement that your unit is set to. To change from yards to meters and vice-versa, touch the tab, and then touch "Done" on the bottom of the screen, to save the setting. https://golfbuddyglobal.com/doc/usermanual_worldplatinum.pdf
Mar 07, 2018 | GolfBuddy GPS
Yard to meters
1 yard = .9144 meters
I am guessing that is not the answer you want but more like how to change the reading from yards to meters on your compact 800 measuring unit
read the user manual to find the mode button and select distance or yards and change to meters
no manual , download one from the web site for the manufacturer
Jan 24, 2017 | Heating & Cooling
V3 change meters to yards
MODE and UNIT OF MEASURE OPTIONS
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower
right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will
begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature,
see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to
select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the
M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite
will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Aug 03, 2014 | Bushnell Tour v3 Rangefinder With Slope
V3 not jolting
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature, see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Feb 12, 2014 | Optics
A land developer wants to find the distance across a small lake in the middle of his proposed development. The bearing from A to B is N14^0W . The developer leaves point A and travels 53 yards...
f.
You'll probably have finished your homework by now if you worked on it instead of typing it in to FixYa. Besides, how much do you trust me?
Sep 25, 2013 | Optics
mtg
Oct 08, 2009 | Bushnell Yardage Pro 500 Rangefinder
Incorrect distance or Calabrated wrong
Sounds like the unit is reading in meters instead of yards....Hold down the mode button on the side for about 5 seconds. It should switch modes.
Jan 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
Acurate distance measuring
hold down the mode button for at least 5 seconds and it will change from meters to yards....or vice versa
Sep 17, 2008 | Bushnell Tour V2 Pinseeker Laser...
Bushnell Yardage Pro Scout Rangefinder Logo
66 people viewed this question
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Goldi Kunal
Damen Wong
Damen Wong
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
