I can't get my humidity above 31%. I have the control all the way up to 7 and I can see water flowing. What is the problem?
I have a "General" brand humidifier. Power humidifier on the warm air side and I still cannot get the humidity above 30%. Our house is small 1000sq ft. Brand new 2 stage variable stage blower furnace.
-   i have a new aprileaire 600 a system and humidity is still only at 26% i want it higher 35 to 40 and i called installer he said the unit works perfect,,, even if i turn up the humidistat to raise humidity even to max,,, there is virtually no difference in humidity reading . i use a digital monitor,, i tried everything but i cant get humidity to go up what should i do? and is the unit in fact supposed to be working this way?
-   spanky2525
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find...
(More)
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find one?
Karen Pankratz
pankjp@comcast.net
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of...
(More)
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of replacing hard to find filters of my Holmes humidifier.
Thanks.
we just bought a home with this humidifier installed on the furnace. There's no activity when the...
(More)
we just bought a home with this humidifier installed on the furnace. There's no activity when the furnace is running. The water is connected but does not flow. Could this be a transformer problem? We guess it's about eight years old.
