Question about Freezers
WHAT INFO CAN YOU GIVE ME ON FREEZER model #ffu20fc6cw1
Model #FFU20FC6CW1
This is an older freezer. I do not see a control to adjust the temperature. Was this model pre-set to the freezing temperature with no option to adjust?
Best advice I can give is to check out the manual, if you don't have it, try putting the model number into a search engine followed by manual and you might be able to get the info you require. Remember to always include model number when asking questions if possible.
Sep 02, 2015 | Freezers
Repairclinic com
Call a refrigeration repair guy. He has the proper gauges to hook to your compressor to check the gas in the lines. There is no easy way for this. Sorry, your gas is probably just low, and you need to be licensed to open up and add to or work on this part of the refrigeration device.
sorry,
Jim
Jan 12, 2014 | Frigidaire Freezers
American fridge freezer, ice maker broke. how do I fix it.
When you say not working, do you men the bin control arm is broken off or the water supply is off to the ice maker. Give me. Little more info s to specifics o I cn help better.
Feb 06, 2013 | Frigidaire 12 cu. ft. / 340 liter Upright...
Have 2 door masterbilt freezer model BLG40HD serial LQ400110. need to know what year manufactured
http://www.master-bilt.com/comdir/direct.htm
go to this site. It has info that you can contact them and just give them your model and serial and they can tell you. It's just that easy.
Hope it helps.
May 29, 2010 | Freezers
WHAT ARE THE COMMON PROBLEMS WITH BLUE AIR 2-DOOR
Toll Free # 001-866-677-8500 FAX 001-310-808-0242 / 1-310-808-0262 E-mail 00Admin : info@blueairinc.com / Sales Team : sale@blueairinc.com
sorry couldn't delete it. why not call blueair and ask them product info on that model and see what they say if there is any particular problems with that model. ask about warranty and recalls
1-310-808-0102
1-886-677-8500
info@blueairinc.com
hope this helps
Mar 26, 2010 | Blueair 23 cu. ft. / 651 liter Commercial...
It just quite freezing model lffh2067dw3
I am going to give you the possibilities of why it quite freezing:
compressor not running
freezer fan not running
condenser fan not running
too much ice on evaporator coils
poor air circulation
blocked air vents
overloading food
defrost heaters not working
timer bad (if available)
t'stat not working
try to check what you can... if you are able to pin point let me know then we can take it from there. if not then give me more info so i can give you better help
Mar 11, 2010 | Freezers
Looking for true freezer defrost heat element for t-49f
Most commercial refrigeration supply houses should be able to help you with getting the heater or if not at least give you a steer
as to where to go or who to contact. Some are really helpful, others can be real jerks. Sorry but without knowing the area you are in I cannot give you more info than that. Did you Google the Brand name of the freezer ?????
Oct 29, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Chest freezer
Make sure you have power going to the unit. Check the thermostat for power on both sides going in and coming out. You need to give me more info. before I can suggest anything else.
Dec 23, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
