Question about LG 2.1-Channel Home Theater Soundbar System with Wireless Subwoofer NB3520A
LG Soundbar says no USB - LG 2.1-Channel Home Theater Soundbar System with Wireless Subwoofer NB3520A
I have a LG smart Tv the picture is very good but the picture is very blue ?
What is the model number of your TV?
What are the devices connected to every port of your TV?
Disk; Cable; Antenna; DVD; HDR; Ethernet; USB; Soundbar ?
is the picture better with other INPUT sources ?
Jun 10, 2016 | LG Televison & Video
HOW CAN I MAKE A HARD RESET FOR AN LG SOUND BAR WITH CODE NB2420A
To do a hard reset for LG soundbar las450h or 550 series, long press the volume min button on the soundbar and sound effect button on the remote simultaneously for 10 secs and the soundbar screen will show reset mode. Switch off and switch on the soundbar.
Jun 02, 2016 | LG NB2420A 160W Sound Bar
I have a new 50" Proscan, got a deal on an LG soundbar. I cannot make it work! I have plugged an HDMI from the TV to the input on the soundbar. I have looked at settings on the TV, Help Darcy
On the Proscan unit it appears the HDMI ports are input only. This would be the usual thing on DTVs.
You do not mention the model number but on some Proscans there are L-R line out audio ports you can use, situated next to the USB service port. You may need an adapter cable, such as this one, where you would use the 2 audio plugs only
http://i.ebayimg.com/images/i/272012673439-0-1/s-l1000.jpg
May 26, 2016 | LG Televison & Video
How do I get my headphones to work with my Panasonic smart tv and LG soundbar?
Let me see if I can understand what you want to accomplish.
You have a Panasonic Smart TV, and an LG soundbar. But you want to use a set of headphone. I guess that your TV is already connected to the soundbar, no?
The first thing that you need to check is for an output, it must be from the sounbar, it could be a 3.5mm jack, or an RCA jack. Usually soundbars only have input, meaning that only takes the sound in, never out. If you have an audio output from the TV, you c an always try, but the soundbar won't be use then.
Feb 06, 2015 | LG Televison & Video
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
Lg soundbar says no usb
If your not using USB. Switch it to whatever input you are using. Digital ? Analog? Arc hdmi? Whatever way you are feeding your audio to your sound bar. Usually there's a input or source button on the speaker or the remote. My guess is your using digital optical cable?
Jun 15, 2013 | Audio Players & Recorders
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
How to set up LG NB2020 40W Soundbar
Connect optical cable to soundbar and tv. Plug in the soundbar.
One gotcha -- the red light on the soundbar means the power is off. No light means the power is on.
Jan 16, 2013 | Audio Players & Recorders
Connecting an LG soundbar to non optical digital tv
I'm pretty sure your soundbar has more than 1 input. Check your manual. There probably is AUX input on soundbar and that will allow you to connect to TV, assuming that your TV has any audio out. It could be either white and red RCA connectors or headphone jack.
Mar 07, 2018 | LG Audio Players & Recorders
Purchased LG HLB54S Blu-ray Soundbar - I would like Multiregion
Just got the software to unlock it. It you dont have please let me know your model so I can send you the file. Quite big though.
Jan 09, 2010 | Televison & Video
LG 2.1-Channel Home Theater Soundbar System with Wireless Subwoofer NB3520A Logo
210 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
