Question about Toshiba BDX1300KB Blu-ray Disc Player - 1080p - Black - Dolby TrueHD,
Toshiba BDX1300KB turned it on for first time comes onto screen brings up set up menu then goes off saying no signal
Goes to set up menu,then before i can set it up it goes no signal?
SOURCE: toshiba 32a33 32"tv
My dad and I fixed the TV/Video problem over the weekend using one of the solutions suggested. Make sure you stay away from the red wire running from the back of the tube to the circuit board.
1. Take the cover off the back of the TV.
2. On the bottom of the TV is a circuit board that is mounted on top of a plastic tray. Remove the cables running from the speakers by squeezing the tab on the white plug and pulling them up and off the board.
3. Looking at the back of the TV, pull the board+tray out (barely secured in there) and flip it 180 degrees so you're looking at the front of the board.
4. Desolder and remove the TV/Video push button. It's labeled on the PCB, and should be the second button in from the left.
5. Place the tray back in the TV and make sure the other buttons still remaining on the baord are aligned with the buttons on the front of the TV.
6. Put the cover back and you're done.
TV works as good as new again. Of course I can't use the TV/Video button on the TV itself, but the remote handles that fine. 20 minutes max, and no repairman needed.
Posted on Jul 07, 2008
Ray-Tosh
  • 124 Answers
SOURCE: Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Posted on Sep 28, 2008
  • 15 Answers
SOURCE: goes on and off on and off permantly
your backlight is going out.. get it replaced
Posted on Feb 01, 2009
  • 4234 Answers
SOURCE: Unsupported video signal
It is possible that Jewelquest changes the screen resolution to one that is not supported by the TV. I am not familiar with Jewelquest, but the typical reason for the unsupported message is a resolution outside of the supported range. The supported resolutions should be listed in the owner's manual. Dan
Posted on Jun 12, 2009
SOURCE: when i turn my toshiba regza on I cannot access
Try either the "content / menu" button between the volume and programme buttons. Failing that, when the tv has been powered up from the wall socket wait untill you hear a small click from the t.v (usually about 5 or so seconds after it has been switched on) before switching it on from the remote control, have no idea why this works but the dtv has worked for me ever since I powered the tv up like that
Posted on Jul 17, 2009
How do I make my toshiba bdx1300kb region free ?
Look for cero code in your user manual; input with menu setting.
Jul 29, 2014 | Toshiba BDX1300KB Blu-ray Player DVD...
Toshiba lap top - satellite - when i turn it on it brings up a black screen with red writing - saying TOSHIBA and under that it says press F2 for boot selection - pressing f2 does nothing - if i hold
try pressing the F2 key during the boot process to enter set up (bios)
using the arrow keys navigate to advanced bios features press enter make sure its set to boot from your hard drive
press F10 to save to cmos restart
hope the helps
Oct 06, 2012 | Toshiba Satellite Computers & Internet
I'm setting up a new 42KE5300 and when I turn it on it goes to an LG logo with time input field. I can't enter the time and I can't get past this screen!? The screen flashes and the logo turns upside down...
LG has a general manual that is supposed to cover most of their recent European region models. On page 170, it says if you are receiving a digital TV signal while in AUTO mode, the time is set to GMT plus a time zone/country offset that you can program in manually.
Have you verified that your remote control is working? If you can't turn the set on or off with the remote control, it may have a dead or improperly installed battery (I know it's "new" but I have seen dead batteries in new devices before).
According to the manual (page 76), you should be able to bring up the primary menu by pressing the Menu button, then you can press one of the four-way navigation buttons to step to a sub-menu. Next, you press OK to select the sub-menu. Use the up and down buttons to select the menu sub-items (these are not the up and down buttons on the four-way selector). If none of this works, and you have a known good battery in the remote control, then you probably have a defective product or it is locked into some sort of store demo mode.
Jan 16, 2011 | LG Televison & Video
Toshiba 56HM66. Picture freezes, then picture goes out. The blue light stays on and the yellow light blinks 15 times, 15 times, 15 times and then the picture comes back. The voice never goes out. This...
this is a digital board problem. Part# 75004946.
has to be data transferred from dmd board. options menu in service mode. scroll down to dmd>digital transfer. press left arrow on remote to initiate. when says ok exit on remote an shut off................. Meder's Tv
May 01, 2010 | Toshiba 56HM66 56" Projection HDTV
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Toshiba L300/L300D installation problems
The best thing to do is reinstal windows from scratch.
Dec 25, 2008 | Intel D845GEBV2 Motherboard
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Cant get onto the menu screen
I finally figured it out!!! There is a button on the right-hand side of the camera, which switches it from normal mode to simple mode. Just press the button and everything goes back to the way it was...
Feb 24, 2008 | Olympus Stylus 730 Digital Camera
Toshiba BDX1300KB Blu-ray Disc Player - 1080p - Black - Dolby TrueHD, Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
