Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Neither my washer or dryer has any power on our electric stackabl
No power on either one not just the dryer but also the washer and I checked the breaker already,is their a fuse or a reset button?It is a GE if that helps.
Lights on but does not work
Posted on Apr 07, 2011
  • 65 Answers
IT IS GOOD THAT YOU STARTED WITH THE HOUSE ELECTRICAL. I WOULD NOW CHECK THE POWER AT THE RECEPTACLE AND THEN TAKE THE COVER OFF THE BACK OF THE MACHINE WHERE THE CORD CONNECTS TO SEE IF MAYBE A WIRE IS BURNT OFF. I HAVE SEEN THIS TOO MANY TIMES TO PASS CHECKING THIS.
Posted on Jan 27, 2009
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Can a stackable washer and dryer be both gas and electric?
yes, the washer is electric, and the dryer could be gas, all though i have only seen in a stackable modles that i use to eliver for sears, that it was also electric, thats not to say thatthe anufacure does not make it
Mar 29, 2011 | Washing Machines
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Stackable washer dryer
hi thanks for the question the washer has a separate cord for 110 volts see if its plugged in thanks the appliance doc
Sep 27, 2008 | Kenmore 62602 Electric Dryer
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
159 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
