Question about Techko SH2106PA Shredder
I need a gear for my shreder so can you help me the big gear that has a small one one it is striped out
    Top Expert:
  • Techko Master
  • 51,545 Answers
Sorry they do not sell those , just buy a new unit
Posted on Mar 30, 2017
Bosch gbh5 will keep loosing its hammer
It sounds like the gearbox oil is getting low. The GBH5 uses oil in the gearbox, not a grease - the grease is used for assembly only. The correct type is a PG-150 (fully synthetic gear oil). Unable to find it in small quantities, I now use PAG150 oil for automotive a/c systems, it's available in small bottles. As for quantity, no-one seems to know... I just fill to cover the big bottom gears.
Jan 18, 2014 | Bosch Brute Breaker Hammer 11304
Hi I have a Aurora AS1512X it was working fine until I emptied the basket. It only goes in reverse now. Nothing lights up when I press auto for forward.
I was having the same problem with my shredder. Always make sure your shreder is not under warranty before you open it because once you open the shredder it voids the warranty with Aurora! I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Mar 28, 2011 | Cross AS1512X Shredder
'Transmission slips in 1st, all other gears fine, makes a clicking sound and slips in and out of 1st at about 3000RPM would like to know if i have to tear down completely, and if so, how big of a job is...
HI, FIRST THING I WOULD DO IN THIS CASE WOULD BE TO DRAIN THE ENGINE OIL INTO A CLEAN CONTAINER AND CHECK FOR PARTICALS OF METAL, A WORN GEAR COULD HAVE BROKEN TEETH OR DOGS, THIS WOULD BE VISIBLE WHEN POURING THE OIL FROM THE CONTAINER. IT WOULD BE A BIG JOB, REMOVING THE ENGINE AND STRIPING THE BOTTOM END OF THE ENGINE TO REMOVE THE GEARBOX, NO NEED TO STRIP THE TOP END OF THE ENGINE, IF YOU CONTINUE TO USE THIS MACHINE FURTHER DAMAGE WILL OCCURE, CONTAMINATED OIL WILL DAMAGE OTHER ENGINE PARTS, BIG END SHELLS, PISTONS ETC.
HOPE THIS HELPS,PAUL
Dec 26, 2010 | 1999 Suzuki GSX-R 750 X
Can u replaces blades on champion shredder
you can but as with all older type shreders it is far cheaper to sharpen the blades as with the pinch roller feeders they wear down and slip when taking in paper . in this case they just need to be wire brushed to allow the small prongs to patrude to catch the paper.
hope this helps
Jul 28, 2010 | Office Equipment & Supplies
I need the EXACT location of the fuel pump location (relay) I found the relays under the hood but the writing on the cover is all worn off
the fuel pump relay has 1 big red wire with a stripe on it and a small gray wire and 2 blk wires one with a stripe on it and possibly a small orange wire all going to the plug on the bottom of the relay
Jan 22, 2010 | 1993 Nissan Sentra 4 Door
Need to find shreder valve
looks like a tire valve. for fuel, its located on injector rail above intake. for a/c there are two, one big and one small, 1 @ COMP,& 1@ dryer.
Jul 17, 2009 | 1989 Isuzu Amigo
Motor gear has worn out.
i doubt if you will find any available parts
Jul 04, 2009 | Office Equipment & Supplies
How to clean my jack lalanne power juicer
Take the top part of the juicer off so that just the shreder is visable. On top of the shreder are 2 small holes on either side of the blades. a handle devise with 2 pins came with the juicer. put the tool pins into the holes and twist counter clock wise. The blade will come off then rest is simple and the unit can be disassembled. If you have lost the tool disassembly will be more dificult but can still be accomplished using a cloth on top of the blades and twiting counter clock wise. Careful though or you will cut yourself
Jan 05, 2009 | Jack Lalanne Power Juicer 250 Watts
I have a SX102M paper shreder that wont shrede
It's the paper sensing microswitch. Wire a small toggle switch and drill a small hole for it on the far right side of the top housing. Just remember that the switch has to be turned off when you are finished shredding or the motor will keep running till it burns out
Nov 21, 2008 | Cross Infoguard Shredder SX102M
Poor printing
Ok,
found a (the?) solution deep down in the web, and it worked for me: The four cartridges are hinged in a big gear wheel left and right of the printer. The wheel is driven by two small gear wheels sitting on a shaft abovee. It can happen that the gears jump one or two tooth on one side, then the cartridges are no longer aligned with the transfer drum (you can see the different gap size from top).
Solution: Take out the cartridges, the drum kit and the fixing unit. Select the black cartridge. Undo the power cord. Undo the side panels (screw at the bottom, then hooks). Take off the rear top panel at the printed paper bay (there are screw driver signs left and right, lift there. Do not try to lift this panel from the back side). Take a close look at the gear wheel linkage of the top cover at the right side, you need to reasemble this afterwards. Take off the top cover. Now you can see the shaft with the small gear wheels driving the big ones that carry the cartridges. When the black cartridge is selected, the two little notches on the small wheels must align with a pale stripe on the big wheels. You can bend the big wheels a bit to move the gears towards each other. You can turn the wheels when you lift the electromagnetic lock on the top right side. Once aligned, put back the top cover in place (with the linkage on the right side). Then you can start a test run after cartridges, drumkit and fixing unit are back in place.
Hope this helps you!
TB
Oct 14, 2008 | HP LaserJet 2550n Printer
Techko SH2106PA Shredder Logo
48 people viewed this question
Top Techko Office Equipment & Supplies Experts
Adorjani Laszlo
casper muchato
Level 1 Expert
Tom Chichester
Are you a Techko Office Equipment and Supply Expert? Answer questions, earn points and help others
