Question about Dryers
How to replace the ignitor on the maytag bravos mct gas dryer
catriver
  • 878 Answers
SOURCE: Gas dryer not heating up
Flash, did you check the thermal fuse in the back? On a gas dryer the drum will still turn if it's blown. check out the picture and post back.
Posted on Mar 29, 2007
  • 77 Answers
SOURCE: maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Posted on Apr 18, 2009
  • 97 Answers
SOURCE: Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
Posted on Jul 11, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a Maytag MDG9706AWW gas dryer and have
This problem is usually caused by a blown thermal fuse, a faulty ignitor (if it won't light), or faulty gas valve coils. The thermal fuse is located inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long and can be tested for continuity using a multimeter. No continuity would indicate a blown thermal fuse. Hope this helped and best wishes.
Posted on Aug 05, 2009
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
How to trouble shoot bravo maytag mct dryer 7403MBW
all repairs should be serviced by a qualified appliance repair technician.you must first know if your problem electrical or mechanical. technical assistance cannot proceed without knowing.
Apr 24, 2017 | Maytag Dryers
Is there a reset on a may tag bravos mct washer
Top 565 Complaints and Reviews about Maytag Bravos
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.2 - ‎241 votes This Maytag Bravos HE machine has the poorest design! ... So disappointed in Maytag - I have a 2013 Bravos washing machine that if I had it repaired again (less .... Called Maytag because my owner's manual stated I had a 10 yr warranty.
Jul 26, 2015 | Washing Machines
How do I get a maytag bravo mct dryer to show problem codes
It will only show what is wrong w it. The computer will only do what it was programmed to do . You can't make lemonade w apples
Feb 18, 2015 | Maytag Dryers
Check lint screen flashing but lint screen clear. Any suggestions? 3 flat lines in time led readout.
could be trying to tell u there is a line blockage in ur venting somewhere
Oct 12, 2014 | Maytag Dryers
Maytag Bravo gas dryer gets too hot.
Most likely needs a new thermostat. Go online to find instructions on replacement. Make sure it is unplugged. I don't think it is too difficult to do yourself.
Sep 13, 2014 | Maytag Dryers
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
No heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 02, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Installed new gas Maytag Bravo yesterday. It will
is the gas on
sometimes these units get dropped if they fall hard you could have cracked the ignitor
Oct 03, 2009 | Maytag MGDB400VQ Dryer
Dryers Logo
103 people viewed this question
Top Dryers Experts
