Question about Epson ACULASER CX11NF All-In-One Printer
Auto doc feed not working on Epson Aculaser cx11nf printer
The printer does seem to even recognize that it has an ADF. Unfortunately the book does give much info on what the problem might be. I tried unlugging and replugging the connections but to no avail.
It seems the adf died completely.
Please advise if you have a solution. Thanks.
  • Andy Bell
    Andy Bell Feb 03, 2009
    doc feeder initialises but does not recognise it fitted or feed paper
    Problem Solver:
  • 9 Answers
You stated that the printer doesn't recognize the ADF.
Can you scan with the flat bed scanner ?
As for the ADF, first thing to check is the the External Plug from the ADF to the Scanner.
You have already done this.
Only one other thing.
The external ADF cable feeds from a small circuit board inside the ADF to the Scanner then from inside the Scanner to a socket inside the printer on the Main Logic pcb (ESS) which is located down on the left side behind the small door.
If this cable is partially or completely unplugged from the ESS Main Logic pcb then the printer wouldn't recognize the ADF.
However, this is unlikely to be the problem, UNLESS the printer has been recently serviced and the covers removed. Then this cable could have been moved or partially unplugged.
This internal cable (FFC) is not easy to access. The small, left side door is held by a Phillips screw if you remove the door you can see the Flexible Flat Cables (FFC) up at the top (3 different cables & each is different size). Seeing them and removing/reinserting them are 2 different things.
Also behind the Smaall Door is the optional Ethernet card.
These cables are very fragile, they insert into a special socket with a "press down" sleeve to hold them in place. These cables can be damaged very easily if not handled with some care.
Auto doc feed not working on Epson Aculaser cx11nf - moz-screenshot.jpgmoAuto doc feed not working on Epson Aculaser cx11nf - moz-screenshot-2.jpgclass=moz-screenshot-2.jpgTo gain easier access to the cables, the left side of the printer must be removed and this isn't as easy as one might think.
Beyond the above, the official fix is to replace the ADF and/or the (ESS) Main Logic Board.
You might could buy a new CX11NF for what that costs !
If the CX11NF operates ok in all other respects, especially the flat bed scanner, I would just use it as it is.
Good Luck !
Posted on Feb 12, 2009
  • epsinopin
    epsinopin Feb 12, 2009
    Correction: I stated that behind the Small Door was the Ethernet Bd. What I meant to say was "behind the Small Door is the FAX Module".
How do you remove the waste toner from the photoconductor?
Hi Piotr, The link below is a free user manual for an Epson ACULASER CX11NF ALL IN ONE PRINTER, The answer you're looking for is on page 83
Removing and replacing an empty toner cartridge
... CHEERS..
https://files.support.epson.com/pdf/cx11n_/cx11n_ba.pdf
Mar 31, 2016 | Epson ACULASER CX11NF All-In-One Printer
ADF not feeding paper
Try this, check the white plastic flap under the ADF, it should go under the cylinder.
Aug 30, 2010 | Epson ACULASER CX11NF All-In-One Printer
Epson AcuLaser CX11NF does not worik on Ubuntu 10.04LTS
Check the bottom of the comments here for a solution. The Epson AL CX11 now works with Ubuntu 10.04 x64
http://www.gedda.info/?p=132&cpage=2#comment-31938
Aug 11, 2010 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser CX11NF Printer is offline
you need to go to settings ,then printers then right click from your mouse on your printer ,then put it online..thats it...i hope it will work..
Mar 25, 2010 | Epson ACULASER CX11NF All-In-One Printer
Epson CX11NF-Vertical line on output of adf... Vertical line appears only on output of adf scanned docs on Epson CX11NF printer.
There may be dust or dirt on the small glass strip. Lift the scanner unit so you can see the scanner glass. To the left you will see a small glass strip. That is the area that you will need to clean. Make sure it is spotless as any stuck on dirt will cause the problem you are having.
Jan 27, 2010 | Epson ACULASER CX11NF All-In-One Printer
Epsoncx11nf doc feeder inop
This is usually caused by the grey cable connecting the ADF to the scanner unit. A wire inside often breaks and the cable requires replacing by a technician.
Feb 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
ADF jam
Turn off printer and unplug it from power supply.
Check ADF if it appears to be damaged ( open the top portion so that you can check the mechanisms ) unplug the ADF cable from back of scanner and replug it, replug power cable, turn it on and try scanning using adf again.
Feb 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
212 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
