Owners manual for amish heaters - Heating & Cooling
Honda svc100 service
Hi, Amish for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Honda SCV100 SCV 100 Lead Manual
http://bv000245.ferozo.com/despieces/HONDA/SCV%20100%20LEAD.pdf
Honda SCV100 Owner Manual
Sep 14, 2016 | Honda Motorcycles
Amish heater
I have a infrared heater CZ20110 Oak Finish
Dec 26, 2013 | Heating & Cooling
How to clean amish heaters
I was told my Amish heater only needed taken apart and cleaned to make it work nicely again, So is there any instructions that I can look at while I do this so that I don't mess anything up inside the unit ?
Oct 30, 2012 | Heating & Cooling
Can you get Amish furniture picnic tables?
Yesyou can get all types of tables in Amish furniture, but I've seen some reallynice picnic tables - see this link http://www.pinecraft.com/amish-outdoor-patio-furniture/amish-outdoor-patio-tables/amish-picnic-tables.html#.UA-pZfX_nos
Jul 25, 2012 | Furniture
How do i clean the inside of an amish fireplace
I was told to tip the amish fireplace and hold it about 6 inches away from the floor for about 20 seconds then set it back up you can here it reset inside and I was also told they are self cleaning hmmmm I also had mine for more than the warranty and they sent me a new insert at no charge. Cannot beat that I have to call them again casue it runs for a bit then shuts down again all in all they have been great to me and it heats great too
Mar 29, 2012 | Napoleon Heating & Cooling
How do you change a light in an Amish surge heater?
To do it correctly you'll need to see a drawing or picture. It's not difficult and the bulb may only be loose. They do that sometimes from vibration.
For more information and a downloadable manual do to:
http://www.heatsurge.com/help/troubleshooting.cfm#poor-light
If the link doesn't work when you click on it, simply copy and paste it into your web browser.
Jan 28, 2011 | Heating & Cooling
How to change bulb in amish heat surge heater
It's not difficult to change the bulb. But lengthy to explain. If you no longer have your Owners Manual go the link below and click on "Flame does not illuminate properly" More than likely though, the bulb(s) have just come loose.
Jan 21, 2011 | Heating & Cooling
My amish heat surge heater has to bad bulbs in it. I found that the heater is not putting out heat. the fan works but it won't heat. Is it because the bulbs are burnned out?
Sadly, the only thing that is Amish on your heater is the cabinet mantle. The electric fireplace is made in China. Never-the-less, from what you describe, it appears that the heater coil is not receiving power or it has burned out. If it's not receiving power, one of the resistors that controls the power to heater has gone bad (probably melted). The bulbs being burned out does not affect the heater. You must have had this unit for sometime for the bulbs to burn out. Normally these are LED Bulbs that have a tremendously long life. It may be that the bulbs have vibrated loose and need to be re-tighten.
If I recall correctly, these units were sold with a one year warranty and may have had an option of an extended warranty. If yours is still under that one year warranty, you're in business. If you purchased the extended warranty, that's even better.
In any event, contact their customer service dept @ 1-800-924-7964, as they may able to help you even more.
Jan 19, 2011 | Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
