Question about Zyxel P660HW-D1 Router
Nat3 chanche to nat 2 - Zyxel P660HW-D1 Router
  • 4 Answers
Yeah I had this problem but she's fixed. No need to upgrade the firmware me thinks.
1) Type in "192.168.1.1" into the address bar of your browser. The log in page for your browser appears.
2) Enter your password - by default this is "1234", but you might have changed it. If you have changed it before log in with that new one.
A page should load with a lots of boring information. On the left side there should be a panel of stuff, what you want is "advanced settings". If advanced settings IS there on the left go to step "a" below. If advanced settings (or in fact anything) IS NOT down the left proceed to step "b" below.
a) Happy days. All you have to do is click the "+" beside advanced settings to expand it, then select UPnP. Then just click ALL of the boxes (there's 3 of them I think). That's it.
b) You are logged into some sort of stupid mode where you can't change anything. All you can do is refresh the page or log out. This is probably because you entered "1234" as the password, but in fact this password has previously been changed by you or someone else. So go back to the log in screen (192.168.1.1 in the address bar) and put in the one you changed it to, if you can remember it. If you do remember it and log in successfully (successfully being that you can see "advanced settings" on the left), go back to step "a" above. If you still can't get to that page it means you don't know your password. So you're going to have to reset your router. Go to step "c".
c) Resetting your router. Turn the router off. Then hold the reset button for 30 seconds and power on the router at the same time. Now I think you'll have to set up your router again like when you got if first, to connect to the internet, so do it. Then log in to 192.168.1.1 again. This time the password "1234" should bring you to the proper screen with advanced settings. If it does go to step "a". If it doesn't go to step "d".
d) You'll have to default reset your router. Turn it off. Turn it on and hold reset for 15 seconds. Some light will flash. Release button and let it reboot. Now log in to 192.168.1.1 again. If it works and you can select "advanced settings" go to step"a". If you STILL can't see advanced settings you're at the end of the line and I don't know what to do. Contact your provider or something.
If you haven't done this already...on your ps3 (or similar on xbox):
Open up network >> internet connection. Choose wireless/wired - whichever you want. Choose "Address settings" - "custom", "IP address" - choose manual.Enter these:
IP address - "192.168.1.50"
Subnet Mask - "255.255.255.0"
Default Router - "192.168.1.1"
Primary DNS and Secondary DNS same as default router.
Then enter than. Don't know what MTU is (it'll come up next). You're done.
Posted on Feb 03, 2009
Can't play other players online with PS3 because of NAT3 network configuration.
There are many reason as to why NAT3 is not open. First is the ISP's modem, verify from your ISP is set into full bridged mode. If it is just half-bridge, informed your ISP to help you set modem into full bridge mode. Second is forward the port numbers TCP: 80, 443, 5223 and UDP: 3478, 3479 in your router. You will access the set-up page of your D-link router and click "advanced tab" and choose "port forwarding"
Nov 09, 2010 | Belkin Basic Wireless Router
I want pass to nat3 at nat2
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Sep 23, 2010 | Belkin Pre-N (F5D8230-4) (DBF5D82304)...
How do you change from nat type 3 to nat type 2 on this router
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Jun 22, 2010 | Siemens SpeedStream 4200 (13A4200001)...
Change nat type
To reduce the NAT
Mar 31, 2010 | Arris WR850G Router (DHWR850G)
Lg 566lm says out of range
chanch the resolution from your computer in a lower sise like 1024 - 768 0r 600 - 800
starting computer in save mode
click on desktop with richt mouse click and chanche resolution
Oct 07, 2009 | LG Computers & Internet
Nat type is strict
Playstation Guides ( PS3 ) to change from NAT3 to NAT2...
Guide1 or Guide2 or Guide3
Feb 02, 2009 | Netopia 2247NWG-VGx Wireless Router...
Have you fix you problem router and xbox live
Jan 30, 2009 | Linksys Wireless-G WRT54G Router
Chanched NAT and got locked out.
Once you have logged into your router, enable the DMZ feature and put in the IP address of your 360.
This will put your 360 outside of the routers firewall and it will give you a full open connection to XBox Live.
Dec 02, 2008 | Belkin (F5D5231-4) Router
Nba live08 lagging on-line
Try starting a game with people you know locally, if your ping between users is too high it will be perceived as lag. when the server catches up with you, your system misses the refresh cycle with the other players and it disconnects you. a more responsive internet helps. Also if you are at a NAT3 connection it can cause problems. check your internet settings and see what it says, there are many online guides to setting to a lower NAT.
Hope this helps.
Mar 28, 2008 | Sony Playstation 3 (PS3) Console
Zyxel P660HW-D1 Router Logo
161 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
