Question about Max-Fridge Refrigerators
Wiring diagram fridge freezer indesit ff520 thermostat
  • 54 Answers
SOURCE: Indiset Fridge not cooling
If the compressor is running and not cooling then there is no refrigerant circulating in the refrigerator or no air moving across the one or both coils. No ice in the freezer section indicates that no cooling is taking place at all, pointing to a lack of refrigerant rather than poor air circulation due to a bad fan or frozen coil.
You can try a manual defrost to ensure it's not a frozen coil by unplugging the unit for several hours with doors open then starting it again. If there is still no cooling occurring you need to check the refrigerant level. If its low you will have to find and seal the leak, pressure test with nitrogen, evacuate and weigh in the correct amount and type of refrigerant listed on the unit.
Hope this helps, needless to say be sure to find a reputable qualified technician to open and service your refrigerant circuit this will make or break your unit.
Posted on Mar 15, 2008
Healeyman
  • 1198 Answers
SOURCE: Need a wiring diagram for a Hotpoint fridge freezer
Check Repairclinic.com, it's a good site.
Posted on Apr 27, 2009
  • 306 Answers
SOURCE: fridge is on but not cold. thermostat is on right temp but not fridge and freezer not cold at all
See if frost is on rear of freezer panel. posssible defrost heater ,relay, or timer quit.
Posted on Apr 30, 2009
venexcsd
  • 1185 Answers
SOURCE: Indesit fridge keeps running
Either the motor relay is stuck in the on position or you need a new thermostat.
The thermost control can be withdrawn from the casing inside the liner , if you do so then take the power off before you try.
There is normally only one screw holding the stat in position and the unit will pull out far enough to allow you to remove one of the leads attached to it.
Make sure that the lead is taped over and then switch the freezer back on again
The motor should not run, if it does it is not the stat and you will need to check out the compressor motor relay for burning.
If you are not sure then ring for someone to come out who is qualified
Posted on Jun 15, 2009
  • 39 Answers
SOURCE: Freezer does not get cold enough...
your defrost t-stat is located behind the rear frzr panel. it's a round disk w/ two wires, org/wht. if you see heavy frost built on the rear panel, then you a a defrost. it could be your timer, heater or t-stat. if i knew your model # and can tell you how to advance into the defrost cycle.
Posted on Jul 16, 2009
My Indesit fridge does not get cold, both the Refrigerator and Freezer.
ok.. none of what you have done involved taking the back off.. if you can get to the compressor itself, you will find it has a dinky 'computer' style fan.. but invariably, some fool of a designer, runs wires very close, and uses low quality cable ties.. which break, causing the wires to spring up and jam the fan.. (especially if it has been moved recently) significantly reducing your compressors ability to chill your appliance.
get some decent cable ties, check and secure rogue wires, and things should sort themselves back to the right temperatures within a few hours.
Apr 24, 2017 | Indesit Refrigerators
Fridge freezing food adjusting thermostat make no change
Sounds like the vent is stuck open on your model. Here is a service bulletin for your model=> HERE
APPLIANCE 911
Dec 14, 2015 | Indesit BIAA134 White 292 l Fridge Freezer...
I am requesting a wiring diagram please
then perhaps request it from the manufacturer who by the way you forgot to mention in this question
Aug 24, 2015 | Refrigerators
How to connect new thermostat to indesit inc325aiuk
http://elektrotanya.com/indesit_inc325aiuk.pdf/download.html Again not a US Product and why, pray tell, did you disconnect the old thermo before obtaining a new one?
Simple replacing one to one gives you the original connector matchup.
Jun 14, 2014 | Water Heaters
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Fridge is running but won't get cold
if it have one compressor the gas in the system are low . but if it have 2 compressors the thermostat can be the problem
Jun 01, 2009 | Refrigerators
Fridge is on but not cold. thermostat is on right temp but not fridge and freezer not cold at all
Apr 30, 2009 | Refrigerators
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Refrigerators Logo
Top Max-Fridge Refrigerators Experts
Dan Stewart
Dan Stewart
Level 1 Expert
mike simpson
Tom Chichester
Are you a Max-Fridge Refrigerator Expert? Answer questions, earn points and help others
