Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water and Icemaker do not work
I was given a Kenmore side by side refer with water dispenser and Icemaker. I have replaced the filter and the water dispenser works the first time I use it after putting the filter on. After that, it does not work. I can remove the filter and put it back and it works the first time, but not after that. The icemaker appears not to work since the water does not work.
    Problem Solver:
  • 12 Answers
Sounds like you need a knew water valve. It is located on the back lower left corner of the fridge.
Posted on Jan 31, 2009
Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
Aug 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
The water dispenser on my kenmore side by side has stoped working.
I have no solution, I need help getting onto facebook. Please update your page giving us an area to log in for those of us who are already members.
Feb 26, 2014 | Computers & Internet
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
The water dispenser quit working,i can hear motor/unit turning,would a plugged refrig filter be part of problem?
Yes a clogged filter could indeed make the water dispenser not work...it too would affect the icemaker as well, is ice being made?? if yes icemaker is working yet no water being dispensed what ya need to check for is a cracked or broken line and instead of water is leaking out of it somewhere.
GENE
Sep 23, 2011 | Kenmore Side by Side Refrigerator
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser reader not responding
no water flow is caused by the icemaker valve
on the back of the refrigerator
the water line is connected to it.
if it is stuck it will not let water through to the
icemaker
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
124 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
