Question about Cornerstone CHAINTECH 7AJA Socket A ATX Motherboard W/ AUDIO (
Jumper settings i need the jumper settings for this motherboard i cant get it to power on
  • 56 Answers
GO TO MOTHERBOARD MANIFACTURE WEB SITE.
WWW.MOTHERBOARD.ORG
MOTHERBOARD DOWNLOAD DRIVERS
MOTHERBOARD UPDATES
WWW.CORIMAGE.COM
CANDYMANGANDY
Posted on Jan 27, 2009
Where are the jumper (pins) on a KONA-SVT motherboard?
Sorry don't now where jumper is for this model. However, most jumpers are located not too far from the bios battery. If you still can't find the jumper try disconnecting the power source from the motherboard, remove the bios battery, then press the power switch to dissipate the capacitors. Wait 5 minutes then re-insert the bios battery and reconnect power to the motherboard. You should now be prompted by the bios to set the time when you start the computer. Good luck
Nov 27, 2015 | Lenovo Computers & Internet
Motherboard msi 7610 ver 2.1
To reset the motherboard: set the dipswitches at OC_SW1 to ON-OFF-ON, then clear the CMOS Ram by setting the jumper at JBAT1 to pins 2&3 while the power is OFF. Wait fifeteen seconds,Then return the jumper to pins 1&2 and turn the power on. This will re-set you to the factory defaults. You will need to enter the BIOS and re-configure your hard disk. The manual can be downloaded at ECS's website at: http://www.msi.com/product/mb/P41TC31.html#/?div=Manual
Apr 18, 2014 | MSI Ms-7610 P41t-c31 Motherboard Intel G41
My motherboard (intel DG41WV) is starting but not giving output to screen. I have cheked cables sokets. Even i have cheked to other screen. but problem is still. all peripherals (fan, cd-rom...etc) are...
Jumpers:
Motherboard installed in computer case;
A) Keyboard Jumper Block
3-pin jumper block, Top of motherboard/ left side. Near the mounting hole, and 4-pin ATX +12 Volt power cable connector,
GENERAL example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ This power cable MUST be plugged into the motherboard.
It is power for the Intel processor ]
3-pin jumper block.
Starting at the TOP coming down;
Pins 3, 2 and 1.
Jumper cap should be on Pins 2 and 3.
(Enables the Keyboard wake-up feature. Factory default setting is Enabled. Pins 2 and 3)
B) Clear CMOS Jumper Block.
BOTTOM right corner of motherboard. 3-pin jumper block.
It is to the Left of the bottom/left SATA connector.
It is immediately to the Right of the motherboard mounting hole.
Starting at the Top, and going down towards the bottom edge of the motherboard;
Pins 3, 2, and 1.
Jumper cap should be on Pins 1 and 2.
When you changed the SMPS, do you KNOW for a fact it is a good one?
Did you plug the 4-pin ATX +12 Volt power cable, into the motherboard?
What COMS setting/s did you change?
I would go back into BIOS Setup, and set that menu screen back to the factory default settings.
[ Load Optimal Defaults ]
BIOS Settings Glossary,
http://download.intel.com/support/motherboards/desktop/sb/biosglossary_v18.pdf
Regards,
joecoolvette
[Motherboard manual - http://www.intel.com/support/motherboards/desktop/dg41wv/sb/CS-031417.htm
Nov 11, 2012 | INTEL - MOTHERBOARDS Computers & Internet
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Bios boot password on a Toshiba c655-s5049
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps dont forget to vote!
Feb 25, 2011 | Toshiba Computers & Internet
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
Feb 10, 2011 | Foxconn A88GMX AM3 AMD 880G HDMI Micro ATX...
Hi, I messed up my BIOS by trying to update it... I got an asus p4b533 and cant find how to do a CMOS reset. I read about shortening two bumps because this board obviously has no jumpers to reset CMOS....
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Hope this helps
Jan 16, 2011 | ASUS P4B533-VM Motherboard
USB ports on asus CUV4x-d arent putting out any power. on boot sends me to settings screen, asking for a keyboard to be plugged in, but i cant get one to work
check the jumpers on your motherboard in the vacinity of your usb cable or, ports make sure the jumpers are activating the usb circuit
Jan 25, 2010 | Computers & Internet
Vt82c693a motherboard cant show ide hdd in award gui bios check
There may be a need to check the Jumper settings on the IDE drive, I would make sure the jumper is in the master setting and also to try to keep the cd rom connected also when you boot it up again.
Blessings,
A/V Media Guy
Nov 21, 2009 | Computers & Internet
My board will power up but i cant get any video dont know where to srt jumpers
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 10, 2009 | PC Chips P23G Motherboard
Cornerstone CHAINTECH 7AJA Socket A ATX Motherboard W/ AUDIO ( Logo
176 people viewed this question
Top Cornerstone Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
 steve
steve
Prariehog
Prariehog
Are you a Cornerstone Computer and Internet Expert? Answer questions, earn points and help others
