Question about KitchenAid KAWS750L Top Load Washer
Necklace caught under the agitator
How do I remove the agitator piece to get to a necklace that's wrapped around the underneath of it?
  • 15,935 Answers
In the center of the sgitator, there is a bolt.
Sometimes there is a plug to remove by prying out.
Remove this bolt.... or just loosen it, and the necklace will come free.
See item 2 in the expanded view on the left side.
Thank you for using FixYa - A FixYa rating is appreciated!!
Posted on Jan 26, 2009
    Sergeant:
  • 311 Answers
Hi fiveateam.there is a cap on top of agitator ,pop of with flat head screw driver.reach in and pull out the round plastic piece with small handles on it.then you will see a bolt.its 7/16you will need an extension.once that bolt is off you can lift off your agitate.glad to help God bless ,tom ps if having trouble getting bolt back in ,place plastic packaging in the 7/16 socket and then force bolt in the socket
  • 130 Answers
Pop the top off, then the cover inside you should see a bolt take that out, pull top half out. then you should see another bolt to take of and you have it.
Where can I get the best quality of chokers?
The choker is a close fitting necklace which is worn around the neck. It can be made of a variety of materials, including velvet plastic, beads, metal, leather such as silver, gold or platinum, etc.
I can suggest you the name of some of the best chokers :
1) Black Daisy Flower Lace Choker Necklace
2) Black Imitation Leather Choker Necklace
3) Black Velvet Stripes Retro Choker Necklace
4) Delicate White Lace Wedding Chain Choker
5) Double Leather Strap Choker Necklace
6) Double Leather Choker Necklace
You can buy best choker necklace online. All of the above chokers are available online, you can easily get it from there
Sep 04, 2017 | Pets - Others
Trim on blanket caught between agitator and drum. How do you remove agitator on this model?
The agitator simply lifts off the shaft. Grab it and pull upward with a little force, and it'll pop free. Under the agitator you'll find a plastic drive coupler that has a single bolt through the top. Remove this bolt and remove the drive coupler. Whatever got wrapped around it you'll find underneath and should easily come out now.
Aug 16, 2013 | GE GTWN5250DWW Top Load Washers
In the cup holder by the brake, it has a hole in it and my necklace fell through, need to remove console so I can my necklace.
you can also get a small telescoping magnet from the autoparts store and stick in hole wiggle around and possibly get it that way as well.
Apr 03, 2011 | Pontiac Grand Am Cars & Trucks
/There is a gold chain necklace wedged under the agitator. How do I loosen the agitator so it will lift up just an inch or so?
remove center downy cap on top of agitator get a 7/16 socket and long extension and hold base of agitator and loosen screw in center of agitator pull up agitator out of washer...
Jan 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag MAV6200AWW Atlantis Washer. A necklace got caught in one of the bottom holes of the plastic tub - It must be knotted on the other side, as I can not pull it through. I do not want to break...
There is no "simple" way. Under the part with the holes is the tub without holes that holds the water in. If the neclace breaks it will go to the drain pump and most likely be blown out the drain. However you can try putting a few drops of vegetable oil on the necklace allowing it to go down below, and wiggle it around in an effort to untangle it.
Nov 10, 2010 | Maytag Washing Machines
I think my daughter left necklace in laundry. I
Unfortunately there is no filter for these. You might get lucky and be able to remove one of the drum paddles inside the tub, and on some models there is a hole where you can see between teh tubs. Even then it'll be pure luck if the necklace is in the right place. Otherwise, it's just a matter of waiting until it goes into the pump, and likely jams it and needs to be removed.
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Necklace stuck in washer
Hold the bottom part of the Agitator,(The part that you are talking about),Undo the very top part in an anti-clockwise direction and it will come right off.Use a wrench to remove the nut on the top of the agitator and then lift it right out,you may need to move it from right to left.You will now be able to remove the necklace.Replace the Agitator the reverse of removal.
DW
Oct 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Daughters necklace caught in washing bin holes
If you cut the chain what is left could possible work its way into drain pump. Jamming it.
Jul 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Necklace wrapped around bottom of agitator
1. Pry off protective cap with knife or small screw driver.
2. Remove agitator bolt
3. Lift off agitator
4. Retrieve Necklace
Regards;
reg501
The FixYa team
Jun 23, 2008 | Roper RAS6233KQ Top Load Washer
KitchenAid KAWS750L Top Load Washer Logo
296 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
