Question about Compatible Konica Minolta Bizhub Pro C5501 C6501-p C65hc Transfer Charge A0u0r71200
My problem is km 6501c is creating yellow line in all color prints
Its a production printer
WHITE LINE THRU PRINT ON KYOCERA MITA KM-3035
clean the LASER glass for that color, if you dont know what that is get a tech out.
Jan 22, 2016 | Kyocera Mita KM-3035 All-In-One Laser...
The blue color is not printing correctly. It comes out sort of pink and greens are yellow. I have a new balck drum. I have put in a new blue toner cartridge. I have tried adjusting color saturation. ...
create a doccument with four identical lines of text.
the text should be as follows:
your text in the colour Black, the cyan, then yellow then magentta
see if they print in the colours you used, if they are all wrong then delete all drivers associated with the printer and delete the printer, then follow the install proceedure again to reinstall, if just one colour is wrong the it is most likely a deffective cartridge.
Dec 06, 2013 | OKI C5100n Laser Printer
Hi. I replaced the black cartridge (yellow almost empty) but if I print a page (only black, the printer skip some lines. Can you please assist me? Surene Whiteman
Printer contain 4 cartridges and 2 printeads. Because the black color skip some lines as you mentioned you need to replace a new printead(not the cartridge) No:88 Black/Yellow color one. For more information visit the following link: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=&cc=us&docname=c00841890&product=2512009
Jan 24, 2013 | HP Officejet Pro L7680 All-In-One Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
A faint line shows up down the middle of the page, when printing a photo
from cnet review of the product
  • Unfortunately, as with the Z1420, fast print speeds come at the cost of print quality with the Z1300. Black text prints, though nicely dark, were beset by obvious jaggedness. The color graphics print had a slightly faded look to it and color blocks showed graininess and faint horizontal striations. Barcode-style patterns were muddled, too. For our tests, we printed color 4x6 photos with the standard black and tricolor cartridges, as Lexmark did not include photo ink tanks with the test unit. The colors were dull, details were hazy, and again, the entire print was marred by graininess and faint horizontal lines. That said, nobody buys a $25 printer to print photos for framing or to create displays for a classroom science project. A $25 printer is a convenience item for occasional reference prints, and as such, the Z1300 does its job.
Inkjet printer quality
(Longer bars indicate better performance)
b.gif Photo b.gif Graphics b.gif Text Canon Pixma iP1800
Good Good Good Lexmark Z1300
Fair Fair Fair Lexmark Z1420
Fair Fair Fair
Sep 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Dec 27, 2008 | HP Color LaserJet 2600n Printer
Yellow Prints in the other colors
Problem seems to be with your Ink Tank(s) or Printing Head. Replace both of them one by one and retry.
Jun 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Compatible Konica Minolta Bizhub Pro C5501 C6501-p C65hc Transfer Charge A0u0r71200 Logo
Top Compatible Office Equipment & Supplies Experts
JonSnell Electronic
JonSnell Electronic
brian92861
Tom Chichester
Are you a Compatible Office Equipment and Supply Expert? Answer questions, earn points and help others
