Question about HTC Touch Cell Phone (Unlocked) - Soft Black
HTC Touch External Port?
I would like to know if an external antenna can be added to the HTC Touch
There is an accessible antenna port directly under the camera's self-portrait mirror, which is apparently designed to pop out for that access.
You can see an antenna adapter made for it from wpsantennas.com at this link:
http://www.wpsantennas.com/wa-1039-htctouchtouchcruisetouchdualtouchpolarisxv6900cellphoneantennaadaptercable.aspx
Just search Google for "htc touch antenna port" for other info on this.
HTH
Posted on Feb 05, 2009
  • 38 Answers
Yes, it is technically possible, however it is completely impractical. You would need to gain access to the circuit board, and 'shunt' a port off of the current antenna. This would take a crazy amount of time, so, a hardware hacker would do this as a hobby, not really for pay.
Posted on Jan 27, 2009
My base model htc touch phone destroys it external sd card
please try to soft reset (restoring it to factory settings.. your device after taking backup of your data, as there might be a virus issue, so soft resetting the device shall solve your issues..
Mar 19, 2010 | HTC S710 Smartphone
How to use External Gps?
Most external bluetooth GPS units uses serial ports to communicate to the GPS software. You don't need to bother with the External GPS thingy in the setting page. If u really ask, u need to pair using BT to the GPS unit. Under bluetooth setting, u can create and outgoing port as well. On your GPS software, point it to look at that port number.
Feb 12, 2010 | HTC Touch Viva Cell Phone
Can an external antenna be added to Garmin 498
Hi
Sure you can use an external antenna.
Here it is
It is however really only useful to allow for decent veiw of satelites when the unit is monuted under a the signal shadow of a cabin or below decks. Any GPS will not perform as well if a decent shot of 3 or more satleites is not acheived. I suspect this is what is hampering your device. Using the external antenna mounted to get maximum view of the sky will eliminate any such issues for you.
Please take a moment to rate this solution. heers
regards robotek
Jul 15, 2009 | Garmin Gpsmap 498, External Antenna With...
How to use the GPS on HTC Touch Diamond
GPS is built into the Touch Diamond. You will not be able to access it as such. It will be used automatically by any GPS enabled piece of software. Try downloading and installing google maps to demonstrate this
Jul 11, 2009 | HTC Advantage External GPS Antenna...
I have external GPS button in my HTC touch p3452 pda . . how to get get gps data from this ??
u need an external gps device bought separately and then trhu bluetooth u can communicate with this software in ur HTC , u have external bluetooth device or not
nowdays GPS is coming builtin so there is no need to purchase separate reciever but in ur PDA it is not built in
pls rate me WELL for info !
May 20, 2009 | HTC Touch P3452 Smartphone
Cannot enable my gps on the htc touch
Does your phone service support gps? It may not be enabled in your plan. Other than that man im empty. I hope that helps you though
Mar 29, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
My Nuvi 660 powers on but fails to locate satellites. I have updated the machines but alas no workie. Please help
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 22, 2008 | Garmin GPS
Lg vx8350 Using external antenna port. Phone now refuses to switch back to internal antenna when external antenna is unplugged. No signal now without external antenna. Plug external antenna back in, full...
The Wilson adapter damaged your internal antenna. I talked to Wilson today to get a part number to buy the adapter and the told me they did not recommend using it as it has damaged a number of phones. They also said that LG might have corrected the problem in the newest production models.
Oct 13, 2008 | Lands Phones
Toshiba
There are no connectinos for an external antenna on your laptop model sorry.here is a picture of what it looks like though: The connectors at the top for the antenna cables. If you know someone that is an electronics guru, then order another card ( just in case ) for about $15 + shipping, and have him/her connect
those wires to a TMC or SMA connector somehow. Otherwise,.. just buy a good quality USB Wi-Fi adapter with an external antenna. ( which wouldn't cost much more than the spare Toshiba card and less if you figure in what a good dB gain antenna costs)
Feb 24, 2008 | Toshiba Tecra M2-S730 Notebook
Touch screen failed after I added external antenna
have you tried resetting it (press and hold find, the press power)
Dec 04, 2007 | Garmin StreetPilot 2720 GPS Receiver
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
111 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
