How to reset the program of xerox dc 400
When i turn on the machine the the second monitor show "the setting is erased.initials? what it's mean,and how to fix.....help me please,thanks.
  • 53 Answers
SOURCE: Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Posted on Feb 24, 2008
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
  • 6 Answers
SOURCE: Help with Xerox DC 440ST Machine
This problem can only be cured by a Xerox engineer or by someone who has access to a Xerox laptop. You have to have a special program called AltBoot to be able to reload the software.
The only other way is to replace the SCSI hard drive in the ESS (network controller unit) with one that has been pre-programmed.
Posted on Nov 22, 2008
  • 2072 Answers
SOURCE: Master Reset to Factory Settings - Xerox 432
Yes, you have to go into the service settings and reinitialize the memories. I have to look it up but I will send them to you tomorrow.
Posted on Dec 11, 2008
Mykel_N
  • 315 Answers
SOURCE: Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Posted on Sep 24, 2009
How do I reset xerox 3045
Try this:
1. To reset the NVRAM (this holds the control panel settings), turn off the printer.
2. Press and hold the On Line (0) and Enter (4) buttons, and turn on the printer. Keep the On Line (0) and Enter (4) buttons depressed until the message "Initializing...Please Wait" appears on display (this takes about one minute).
3. Release the On Line (0) and Enter (4) buttons and wait for the front panel to display "Ready." This takes about 45 seconds.
4. Press the Menu Up (1) button until the Reset Menu is displayed.
5. Press the Item Up (2) button until Factory Defaults is displayed.
6. Press the Value Up (3) button to display the choices. To actually reset the factory defaults you would select "Yes."
Aug 03, 2016 | Xerox WorkCentre 3045ni Multifunction...
Fuji xerox dc 400 language
Go through the Menu options until U find Language and chage it to english if thats not possible - uninstal the printer and reinstal it being sure to choose English
Apr 19, 2014 | Office Equipment & Supplies
Trying to clear the memory of a Xerox Faxcentre F116. Do you know the steps to accomplish this?
One needs to know what they are doing when resetting memory to the machine.
When resetting the machine, one needs to consider, the loss of memory data on the copy cartridge counter in the machine.
When resetting memory a copy toner cartridge needs to be in stock with a counter reset card.
Erasing memory will wipe out the old copy/toner cartridge odometer setting, resuling in "Replace toner/cartridge" error.
Please clarify which memory area is being erased.
Aug 05, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Drum sound distorted
Try a factory reset:
alesissr16logo53x41.jpgrmidialesissr16logo53x41.gif Performing a 'Reset' on your Sr16 will will 'clear' it's memory and re-initialize all of it's parameters to the original factory settings. This implies that:
  • All of your User Patterns will be erased.
  • All Songs will be erased.
  • All drum assignments you have made will be erased.
  • None of the above actions should be an issue to you as:
  • It is assumed that at some point you have Download And Save A Copy Of The Sr16's Current State.
  • It is assumed that at some point you have Export any 'User' Patterns you may have programed into your Sr16 and imported them into your _rMidi installation.
  • It is assumed that at some point you have Export any 'User' Kits you may have programed into your Sr16 and imported them into your _rMidi installation.
  • Perform The Reset
    To perform a 'Reset' on your Sr16:
  • Turn the pwer off and wait a few seconds.
  • Press and hold the PLAY and ERASE buttons while turning in the power.
  • Continue holding down these buttons for at least three seconds after turning on the power.
  • If this doesn't fix it, check power adapter. If that is OK then service is required
    Jun 06, 2010 | Alesis Sr 16 Stereo Drum Machine
    LOCK ALL CHANNEL
    If all channels are showing the lockout icon, and all are displaying the frequency 000.0000, you just need to program the scanner. Entering a frequency will remove the lockout.
    If all are showing lockout and programmed frequencies, and the scanner will not function, you need to initialize it. This procedure will erase all data that you have programmed into the scanner and restore it to original factory settings.
    - Turn the scanner OFF, then power it ON again. "Multi-system Trunking Scanner" shows on the display.
    - Press 0
    - Press 1
    - Press ENT
    "Initializing please stand by" shows on the display for about 5 seconds.
    Do not turn the scanner OFF until initializing is complete and the display shows "M000" on the top line and "Bank 0 Ch 0" on the third line.
    Need more information on your scanner? You can download/print the operating manual here:
    http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
    For a comprehensive database of active frequencies and systems in your area, visit:
    www.RadioReference.com
    Bill B
    Apr 21, 2010 | Radio Shack Pro-97 Handheld Scanner
    After I enter a frequencie the enter button doesnt work to enter
    If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
    To RESET:
    - Power the scanner OFF
    - Power the scanner back ON
    - Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
    - Gently press and then release the RESET button inside the hole.
    NOTE: RESET will NOT erase the data that you've programmed into the scanner.
    If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
    - Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
    - "Initializing Please Wait" will appear for about 2 seconds.
    DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
    BillB
    Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
    All channels locked
    If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
    To RESET:
    BillB
    Jan 23, 2010 | Radio Shack Pro-95 Handheld Scanner
    Forgot password to Samsung SMT-190DN
    Hold the remote control's STOP ( ) button for
    longer than 5 seconds. “INITIAL” appears on the display and
    all settings will return to the default values.
    • Press the POWER button.
    Using the RESET function will erase all stored settings.
    Do not use this unless necessary.
    Oct 06, 2009 | Samsung SMT-190 19" Flat Panel TFT LCD...
    Error-9-354
    Hope that helps
    Mike
    Sep 23, 2009 | Xerox DocuColor 12 Color Copier
    Xerox phaser 6180 mfp error code 133-290
    Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
    Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
    Corrupt Adjustmen
    Jun 20, 2009 | Xerox 6180MFP/N Printer
    k24674
    jasbo
    jasbo
