Question about Refrigerators
I have a sunbeam model YL2-27CH2 water cooler-dispencer. In a move Ilost the adapter ring for the bottle to the unit. What is the part no. and where can I buy one. Thanks
SOURCE: Sunbeam water dispenser Model YLR2-5-90HZ3 Ser# 2003
water leak from inside the refrigerator
Posted on Jul 16, 2008
ngafm
  • 166 Answers
SOURCE: GE side by side water dispencer area Leaking
1. How do I get repairs done under warranty?
* If your refrigerator is under warranty, you must use an Authorized Service Company.
An Authorized Service Company can be found by using our Service Locator. Enter your zip code on the Service Locator to get a listing of available service companies in your area.
* You can also schedule service by calling our toll free number:
800-374-4432 M-F 9:00am - 5:30pm.
Back
2. How do I order parts?
* Parts can be ordered through an Authorized Frigidaire Parts Distributor.
An Authorized Parts Distributor can be found by using our Parts Distributor Locator. Enter your zip code on the Parts Distributor Locator to get a listing of distributors in your area.
Back
3. Noises / Sounds.
* Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises.
The following can be sources of these noises:
1. Dish vibrating on shelf - move dish slightly.
2. Floor is uneven or cannot adequately support refrigerator. Use shims or extra support.
3. Items on top of refrigerator are rocking. Place a pad under the item or remove.
4. Refrigerator is not level. Adjust leveling legs or rollers as needed. Add shims in the back if floor is not level from front to back.
5. Refrigerator is touching wall or cabinets. See your owner's manual for space requirements.
* Snapping or clicking sound.
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Back
4. Taste and odors.
* Ice or food has a bad taste or odor.
Ice and uncovered foods can pick up odors or taste from strong smelling foods in the refrigerator or freezer. Cover foods tightly and discard old ice.
* Ice tastes like plastic.
Plastic water lines will give off a taste when first used. It takes one or two containers of ice for plastic to stop leeching. Discard initial container of ice after installation.
Back
5. Ice maker - not making any ice.
* Freezer may not be cold enough.
Temperature must be 5 F. or colder to work properly.
* Water supply valve may be blocked or restricted.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
* Water supply valve may not be open.
Find and open the supply valve.
* Wire signal arm on ice maker is in the up position.
This position shuts off the ice maker. Pull wire arm (bail arm) down to start ice making.
Back
Posted on Sep 05, 2008
SOURCE: sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Posted on May 05, 2009
  • 508 Answers
SOURCE: WATER COOLER DOESN'T COOL THE WATER ENOUGH
clean coils check for temperature setting!
Posted on Jun 30, 2009
SOURCE: Sunbeam Drinking Water Cooler model YLR2-5-24H2
my hot water faucet is broken!!.. when can i get new?
Posted on Sep 28, 2010
My sunbeam water cooler is steady dripping water what is the problem
Make sure the part is screwed in completely. I have expired model ylr2-5-87h3 and no one makes parts !!!!
May 30, 2014 | Tomlinson Sunbeam WATER COOLER FAUCET...
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
The plastic handles that dispense the water are broken
Where can I buy the spigets for a Sunbeam water cooler. I need one for hot and one for cold water. These handles are not strong enough plastic to last the lifetime of the unit. They should be made from metal. If the taps on our kitchen sink was made from plastic you can imagine how long they would last.
May 27, 2009 | Sunbeam Refrigerators
SUNBEAM WATER HEATER/COOLER WITH WATER FILTRATION BOOTLE
i am having the same problem and i lost the model number for it but can you please share the modle number if you have it because i call sunbeam and they need it so they can find it for me! thaky e mail @ hateandlove_1988@yahoo.com
May 23, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Sunbeam water cooler model # YLR2-5-25H2
Mar 26, 2009 | Avanti Hot and Cold Water Cooler
I have a sunbeam water cooler and it leaks can u help me..
Hello dneary55
You said, You have a sunbeam water cooler and it leaks can u help me..
Where is it leaking from?
What is the model number and how old is the water cooler ?
If you are under warranty ( Which is 1 year parts and labor
Below you can find an authorized Sunbeam service center.
http://www.sunbeam.com/servicelocator.aspx?section=kitchen
If not you may want to use a sponsored service center here at fixya.
Waiting to hear back form you
Huuum
Sep 30, 2008 | Sunbeam Refrigerators
Broken door...
Buy a dented unit on eBay and take off the hinges
May 12, 2008 | Oster 12-Bottle Wine Cellar - Black
Sunbeam water cooler SA12587 - no hot water
I have a Sunbeam water coooler YLR2-5 87H
My water cooler is not cooling at all. What should I do?
Nate 901-754-0028 or nstclair1@aol.com
May 11, 2008 | Refrigerators
Refrigerators Logo
254 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
