Question about Sony VAIO VGN-N130G/W Notebook
My sony vaio is only reading some of my mini dvd-rw's
Sony vaio vgn-s460 will read some of my dvd-rw's from my sony handi-camand when it does it is in a vob format not very helpful then my ulead editing software won't open this format
  • jojo1972 May 11, 2010
    Can you verify in the manual that you can change the output format on the camera?
How to Boot Sony Vaio VGN-S460 Laptop without CD/DVD ROM and With bootable USB
If the BIOS does not have the USB as one of the boot options then you cannot boot up with an USB memory stick.
In this case you need to replace the CD/DVD drive with a new one.
Jan 17, 2013 | Sony VAIO CS VGN-CS220J/T Notebook
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
My DVD rw (DW-Q58A) in VGN FS42w won't read CD (both music and data) although it plays DVD video and recognizes blank DVD-R.
It happens if the lens becomes weak. I advice you get an external DVD-RW.
I hope you find this solution is helpful.
Sep 27, 2010 | Sony VAIO VGN-FS742/W Notebook
DVD-RW of Sony vaio VGN-CR590 don't still run after changing win7
About the link you need to download the driver for your DVD-RW drive, have you tried the Pioneer website?
Jan 20, 2010 | Sony Computers & Internet
Sony vaio VGN-s460 when I power up, the vaio screen pops up , then nothing. Any help appreciated
if you recently installed a software or a component, that caused the issue. if removing it or a system restore while on safe mode did not work, please consult the link below for some laptop DIYs
Sep 13, 2009 | Sony VAIO VGN-S460 Notebook
Disk drive malfunction(cant read or write disk)
i fu got help from me by my solution in other problem pls rate me FIXYA if u like
Apr 02, 2009 | Sony VAIO VGN-N110G/W Notebook
Restoring operating system for Vaio VGN-S460
Not necessarily. Formatting the hard drive will only wipe the data on the partition being formatted. The restore partition, if it exists, will still be there.
I have read that the restore partition can be accessed by pressing F10 at startup. As I don't own this sony machine, I can't verify that.
Mar 04, 2009 | Sony VAIO VGN-S460 Notebook
check adapter output also may be problem with dc socket on laptop loose or somthing.
Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO VGN-N130G/W Notebook Logo
91 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
