Question about Vehicle Parts & Accessories
STOCK IN ONE POSITION
AFTER PUT ADRES NAVIGATION IS NOT WORKING.JUST REPEETING''
WASHING FOR SIGNAL'' I CANNOT GET NO MAP NO NAVIGATION.
SOMETIME STARTING WORK,BUT ABOUT 90% JUST STOCK IN
POSITION.PLEASE HELP.
THANKS. ADOLIUS
  • 4,472 Answers
What is the exact make and model of your unit? How long have you owned the unit? How long have you had this problem for? If its not receiving a signal it can't navigate the address. If you need further assistance let me know, also take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Posted on Jan 26, 2009
    Sergeant:
    Scholar:
  • 199 Answers
Its the settings problem.or due to location at present its not receving the exact frequency.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have Google maps on my phone how do I get sound on it when Iam driving,My phone is cinnected to the radio in the car
Google maps starts sound when ur in navigation mode.
  1. Open the Google Maps app .
  2. Search for a place or tap it on the map.
  3. In the bottom right, tap Directions . If you touch and hold the button instead, you'll start navigation and can skip steps 4-6.
  4. Optional: To add additional destinations, go to the top right and tap More Add stop. You can add up to 9 stops. When you are finished, tap Done.
  5. Choose one of the following:
    • Driving:
    • Transit:
    • Walking:
    • Rides:
    • Cycling:
  6. If other routes are available, they will be shown in gray on the map. To follow an alternate route, tap the gray line.
  7. To start navigation, tap Navigate . If you see "Searching for GPS," your phone is trying to get a GPS signal. For example, you might be in or near a tunnel, parking garage, or other location where there's no GPS signal.
  8. To stop or cancel navigation, go to the bottom right and tap Exit.
NOTE:
Navigation is not available in all countries. depends on availability
May 08, 2017 | Google Cell Phones
GPS works sometimes. Other times it wont and has a slash thru the navigation icon. Bad GPS signal??? Software need updated???
You didn't say what brand of GPS system you had, but this explanation should work for you anyway.
My GPS system is a Garmin, and when I see the symptoms you describe, it most likely means that I need to update my maps. But It could also mean that I'm not receiving a good GPS signal due to tall buildings surrounding me, or being out in the country at the bottom of a steep hill. I'd suggest going to your GPS' manufacturer online and see if you can download another user manual for your model, then check inside it to see what those signals mean. When updated, your GPS system should be perfect again, but you'll need to update (by connecting your GPS system to your computer so you can download the updates into your GPS) sometimes once every couple of weeks if updates are made, or new maps are created because of detours and and road closures, etc.. Unfortunately companies sometimes let you know when there are new changes available to their customers.
Its an easy fix and takes very little time. Best Wishes!
Jan 08, 2016 | Bv9370nv Double-din In-dash Navigation A/v...
How do I install my intergrated tail light with turn signals i got the tail light to work but the stock turn signals have about three wires each
The stock turn signals have 3 wires1) Positive for turn signal2) Positive for cruising light (comes on with the light switch's 1st click)3) Ground.Obviously you can either replace the entire turn signal with the aftermarket one and stop using the cruising light or bypass the positive wire for the turn signal only, to the aftermarket one, and leave the original turn signal with the cruising light only.
Feb 10, 2012 | 2006 kawasaki Vulcan 800 Drifter
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
I want to know how to use the GPS
what part of the gps system do you want to use
nokia maps?
gps data?
nokia sports tracker?
google maps?
all these apps use gps but to get the most out of them you need internet on your phone but they are not neccersary but having it makes your expriance so much better
firstly go outside and go to gps data and it should search for satalights if you go to posistioning then click options then satelight status this will show the signal and lock of satelights
the bars shows the signal quality the more of the bar better signal but when they become solid coloured in that means that the phone has locked to the satelight
once the phone connects to several staelights then under positioning your posistional information is given
then you can go to the sevreal maps aplications
all the maps apps work better when you are moving they are not accurate when you are not moving
nokia maps is free for a year then you have to pay
google maps is free
both of these are navigation apps
sports tracker is a app that tracks your movements on a map which is pritty cool
using the apps is pritty simple and you learn to use it quickly
aalso the more you use the gps the quicker the gps finds your location the first time will take a minuite or so
Nov 11, 2009 | Nokia E71 Smartphone
Garmin street pilot i3
after i send the map with mapsource from first minnutes is not seen the detailed maps what were transferred but after the receiver catch signal it apears my map detailed
i put gmasupp.unl file to garmin folder from microsd with key from keygen 1.5 i dont know if its necesary but its working with road 2008 romania @ europe nt v9
Mar 26, 2009 | Garmin nuvi 200W GPS Receiver
Try a GPS reset, exit navigation, click on setup, click on GPS reset. then restart navigation. check the gps status screen to make sure you are getting signals. if not, you could have a failed antenna or GPS receiver in the unit.
Jan 26, 2009 | Fine Digital FineDrive 400 GPS Receiver
MIO P350 cannot get GPS signal
What navigation software you use? All navigation software need to install correct Port and Baud Rate for work - please check it in you software.
If you need help or professional GPS-consultation or unlock you PNA, update navigation maps - please ask
http://www.goodslowprice.com/en/unlock.htm
Mar 28, 2008 | GPS
Navigator map program says no signal detected
I had the same problem today. I restarted my palm, and the problem was solved.
Mar 09, 2007 | Tomtom Navigator Bluetooth GPS Receiver
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
