Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Indicators lights come on
I have a smooth top Frigidaire. I have a back burner that sometimes will work and sometimes wont,also the indicator light that lets you know that the burner is hot, sometimes comes on all by itself when the stove hasnt been in use.also front dual burner stop working ,thought it was burnt out went to order new one change my mind when they told me the price $350.00,I sure this cant be right ,can it?
    Problem Solver:
  • 17 Answers
First thing to check is to put your hand over the burner when the indicator comes on and see if the burner is actually hot! DO NOT actually touch the burner! The smell of your own burning flesh is not so pleasant, and could cause you to pass out with your hand still on the burner or something like that, so be careful. More than likely, the problem is with the burner switch, but could be with anything between that and the actual element.
What did they quote you $350 to repair???? Was that parts and labor, or just parts? Sounds very high. If, however, you have one of the older stoves with a ceramic top that had the element in the top, you have to replace the whole thing to fix one burner, not very smart, economically. Newer stoves use seperate elements beneath the glass top, and so are much less expensive to repair.
Go to the Sears.com website, and click on the parts link (it's in a line of grey typed links, relatively small font, a couple of inches below the top of the website home page, and toward the right side.) Type in your model number on the right side of the parts page where it says to, and it will come up with a parts breakdown that has a list of the parts and their prices. If they never sold your model, you might have to come up with a similar model that they did sell in order to get parts listings that would work.
That will at least give you an idea of prices. You should also look at the switch for that burner.  If the burner won't run on either size setting, I'd suspect the switch or that the power is not getting to that switch.
Remember, you are working with 220 VOLTS here, and be very careful. But if you can handle a voltmeter, you can determine if power is getting to the switch, and getting out of the switch, and if it is getting to the element. You can buy a DVM at Radio Shack or Sears, or just about anywhere else, these days. Elenco is a company that makes decent ones very cheaply, and you can buy them online. Or you might have a friend or relative who has one at home, and knows how to use it around 220 volt circuits....
Posted on Feb 10, 2009
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
Oven will not heat. all the burners on top work fine. what could be wrong?
Usual faults in this order are:
Faulty oven element - check element for holes, blow marks etc;
Burnt off wiring at the oven element terminals - check terminals;
If the oven indicator lights when the oven is turned on it should be the above. If it does not refer below;
Electronic clock set to auto. mode instead of manual mode.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
The control panel lights do not work nor does the oven. all the burners work fine this is a convection oven with a smooth top Gallery series
Check your main breaker in the fuse panel, it may be partially tripped. Turn the 40 amp breaker off and back on. if the display does not return to the stove, the I would suggest you contact a local servicer.
Aug 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
Whirlpool 465 Surface Hot Indicator Light stays on all the time.
Most likely a faulty burner limiter switch. Not sure if they can be purchased separately from the burner element.
-Dave
http://www.appliancepartspros.com/part_details.aspx?part_id=3767588
May 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
178 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
