Question about Gateway FPD1975W 19" LCD Monitor
Power button does not lite up
Power button does not light up when turned on, have power to bach of circut board nothing on screen or any signs of power up.
  • 2,229 Answers
Sounds like the monitor has gone bad on you. Check the power cable--both ends. Sometimes they come loose, especially from the back of the monitor.
Posted on Jan 26, 2009
My tv modle numbercw40t2rw after 2 weeks will not power on power goes to the circut board but nothing turns on
Check the manual for a reset button and/or a in line fuse, also check the power cord and see if it has worked it self loose from the back of the set, and for any possiable breaks..
Feb 05, 2014 | Westinghouse 40" 1080P Lcd Hdtv
Power turns but screen stays black no
Try anouther screen . turn off, unplug, hold in the power button for 30 seconds, release plug in and try agin. this sometimes reset the capacitors on the board. can you hear the sound as it starts up also is there any lites on the back around the power supply?
Oct 18, 2013 | Dell OptiPlex Computers & Internet
47LC7DF, Green light comes on, blinks with remote
When you say that you have replaced the main board i assume you mean the power board? If the green light comes on and blinks when the remote is touched it was never a issue with the mainboard, if it was you wouldnt have any signs of power. In most lcd tvs you have the main board which is normally the power board, the signal board which recieves signal and hold settings of the tv which can be all in one, the other is the inverter board, which scrambles the signal to what you see on the screen, and next we have the back light which lights the screen so you can see the picture, sometimes in certain models as i have learned you can have power/inverter boards which means the inverter and power are all on the same board, in your case i pressume the inverter board is seperate board and probably the issue you need to address, you can buy these online probably the same place you got your new mainboard from. Hope this helps pls post bach what happens.
Feb 01, 2010 | LG 47LC7DF 47 in. LCD HDTV
Vizio 42 hdtv mo picture,no sound
Hi
Thanks for using FixYa. Please check the following—
1. Is Power board output +5V?
2. Is J1 (#19 in the right diagram)connector good?
3. Is DC-DC OK, check the voltage at J1 using a multimeter.
4. Is U4 (3.3V) working ok, U4 is an IC, you’ll need an IC tester or an oscilloscope to check this IC.
After checking this if it still doesn’t work then check P3 D-sub Input (on the D-board). See this schematic for details--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Ds lite battery wont charge i have charged it overnight but nothing the green light goes on but that is it
If the green light is turning on and the screens are staying blank it is a problem with he L2 fuse on the motherboard (located just below the power button).
This can be replaced if you are handy with a soldering iron. If not drop it to a local repair shop it can be fixed for about €20.
Aug 26, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Rear turn signal bulb on passenger side of 1997 GMC Yukon needs to be replaced, how do I do this.
Open your rear door and on the inside jam where the light is remove the two screws.There either a philips or torx head.Rotate out a little and litely pull the other side tabs out of the notches in the quarter panel side.Once you remove the light you will see a circut board with two more screws.Your bulbs are on the inside of the circut board.If your new bulb doesnot work,you may need to replace the circut board,there known to burn out.Hope this helps.John.
Mar 09, 2009 | 1997 GMC Yukon
Acer laptop. it won't start up, when i press the start button, it shows nothing but black screen, and i dont know what to do .... I have the same problem i have an ACER ASPIRE 5920, when i turn my laptop...
hi
in both the computers unplug the power cord and any external device attached to the system.
Press the power while the power cord if unplugged for 1 min exact, plug the power cord and see if this works. As there is extra power on the mother board which needs to be drained out
Jan 08, 2009 | Computers & Internet
PANASONIC TH-42PZ700U - WILL NOT POWER UP
THIS SYMTOM MEANS THERES A POWER PROBLEM DEPENDING ON HOW MANY BLINKS WILL TELL YOU WHAT BOARD OR PANEL IS BAD OR NEEDS TO BE CHECKED IT MAY BE A BLOWN FUSE
COUNT THE TIMES IT BLINKs and i can tell you what internal circut board is bad..
Oct 11, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Need help
If the green lites on bord lites up doesnt mean it is ok. If you check on that board in the middle at the back of the heatsink in the middle, there is two lights, green lights that is not lighting up. If i am wright. You have caps an a transistor on your powersup that is shorted. Take to somebody to fix powersupply.
Jan 24, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Gateway FPD1975W 19" LCD Monitor Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
